eaton rear end
I am trying to find the part number or size for the hub bearings in my ho72 eaton rear axle. i am concerting to disc and want to change these while im in there. I know they are hard to find but a bearing place in town can get then for me. also is ther a correct way to remove theses?
thanks 69k5 |
Hey give Randy Blackbird of Blackbird's Custom Trucks a call
He has dealt with the rearends and has a rear disc brake kit made for them.. 509-534-5219
Support The Board |
I already have the rear disc kit. i will call him and see if he knows about the bearings though. it was ok until i was trying to seperate the hub from the drum and gave the bearing a love tap on one side. :p
thanks 69k5 |
ttt anyone else? blackbeqards is closed
188930 inner bearing
188932 outer bearing 1962 to 1972 used the same ones.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
thank you
![]() ![]() ![]() ![]() ![]() ![]() is that a timken number? Last edited by 69k5; 11-21-2003 at 07:44 PM. |
Those are the GM original part number. I dont have a cross over reference book. Even if you pulled your own you may see a manufacturers number on them.
![]() Join Date: Jun 2003
what gear are you running??
Dwayne
72' GMC Suburban 10 1/2" of Lift, 40" Tires! Waiting for restoration ![]() 67' Chevy, What to do??? And Bad Ass American Bulldogs! |
#9 | |
rod
thanks. iwas able to run them at advance. i forgot em but ill put em up for evryone. Quote:
