Old 05-05-2013, 12:05 AM   #1
BigRed76
BigRed76's Avatar
Steering column grease
I'm in the process of rebuilding a non-tilt steering column for my '71, and I need to know what parts need greased inside of the column, and what type of grease is suitable for this. I know that obviously parts that move need greased, but everything was pretty much dry when I disassembled it. Any input is greatly appreciated. Thanks
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 05-05-2013, 01:38 PM   #2
BigRed76
BigRed76's Avatar
Re: Steering column grease
Anyone?
Zach
Old 05-11-2013, 11:52 PM   #3
BigRed76
BigRed76's Avatar
So am I not supposed to lube any part of the shifter tube?
Zach
Old 05-12-2013, 12:16 AM   #4
68shortfleet
I did this a couple weeks ago. I did the top and bottom bearings of my non-tilt column. The grease in mine was completely dried up from sitting for way to many years. A quick trip through the solvent tank and they cleaned right up. I repacked them with normal wheel bearing grease. Not sure if that was the right kind of grease, but it is certainly better than it was before.
68shortfleet is offline   Reply With Quote
Old 05-12-2013, 12:51 AM   #5
JointTech
JointTech's Avatar
Ive read on here to douse the column in white lithium grease spray.
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 05-12-2013, 09:14 AM   #6
68gmsee
Active Member
68gmsee's Avatar
I cleaned the shaft out of all the old, dried up grease and I also used a thin layer of wheel bearing grease. Here in Texas we have some really hot summer (100 plus) days for weeks on end and I didn't want grease to drip down the shaft.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
