Brake light flashing
I have a 91 suburban 2wd and the brake light just started flashing, any ideas on what could be causing this? Brakes, rotors are new fluid is changed.
Posted via Mobile Device |
Re: Brake light flashing
Dash light, forgot to mention that!
78K & 79C Jimmys
may need to bleed em again
sounds like the proportioning valve needs to reset could pull the wire off and try
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
Robert Olson Transport
![]() Join Date: Oct 2002
I had a similar issue and it was the emergency brake pedal and the linkages that were dropped some and the pedal would bounce a little and make the brake light flash because the spring was weak making the switch blink as it appeared the emergency brake pedal was depressed when it was only flopping some start your truck and see if the pedal has play in it
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
Will try that !
Isn't that an ABS system in that year? 90 and 91.
I had a flashing brake light in my 91 4x4 suburban and ended up being the brake module that was bad. I think there are some codes for that light too. How many flashes are you getting? long or short flashes?
- Jeff 89' K5 Blazer, 2.5" lift, 35" tires ![]() 04' GMC Yukon XL, 3/4 ton, 8.1L |
I unplugged the module next to the master cylinder and that worked!
