05-04-2013, 09:05 PM | #1 |
What is this actually called???
I call it a steering bar, I need a new one and need to know what its really called and if they sell them?
05-04-2013, 09:51 PM | #2 | |
Re: What is this actually called???
That is the "tie-rod". You should be able to get that at nearly any auto parts store.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
05-04-2013, 09:55 PM | #3 |
Thats the part. But, both my tie rods are screwed on to it, its an 86. My 78 has the passenger side made into the bar.
Posted via Mobile Device |
05-04-2013, 10:05 PM | #4 |
Then how about an adjusting tube? Some of the 4x4's, the left tie-rod is really long.
'86 C-30 dually, 454/tbh400 '73 K-20 350/350/205 (sold ) I'm kinda like duct tape- no real purpose, but handy to have around. |
05-04-2013, 10:13 PM | #5 |
I have always heard it called the steering link and the drag link is the one that attaches to the pitman arm.
05-04-2013, 10:14 PM | #6 |
The left tie rod is longer than the right and the left one has a hole in it for the stock stabilizer. It has a nut attached to each side and the tie rods screw into it. Went to get an alignment today and its bent.
05-04-2013, 10:15 PM | #7 |
Thank you everyone for the replys. I'll see if I can find one
05-04-2013, 10:16 PM | #8 |
Second Chance Program
Only place i Know of to get one is LMC truck. But im sure they are everywhere.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt. 77 C20 crew cab Silverado. 396/th400. In work. |
05-04-2013, 10:18 PM | #9 |
Thank you!!!! And they are cheap ha
05-04-2013, 10:25 PM | #10 | |
The entire thing from one knuckle to the other is the "tie-rod". The style just depends upon the year of the truck. The earlier models had; one long rod, one short "end", and the adjuster sleeve with clamps.
The later ones had 2 short ends and the center section was the adjusting sleeve. IIRC, they had jamb nuts on the ends? This made it so that the main rod itself was not a wear-out item, it would only be replaced in the event of damage.
05-04-2013, 10:29 PM | #11 |
lmc says the one I need is for a truck with 4.10 rear gears and w/o 13" rear brakes. my truck came with 3.42 gears, so someone has changed it I guess
05-04-2013, 10:31 PM | #12 |
No silly, Its calling out 9 as a "D". That says, without 13" brakes and 4.10. As in without either of those items. Notice that "C" is with 13" brakes and 4.10's. Your tierods/adjuster tube is original.
05-04-2013, 10:33 PM | #13 |
for some reason when I was reading that, I saw " w/o 13" brakes and with 4.10 gears" ha sorry about that and thank you
05-04-2013, 10:44 PM | #14 |
ok so the part number is 34-1180 it $50.70 shipped to my door from LMC. thank you everyone
05-04-2013, 11:04 PM | #15 |
Your welcome! keep in mind thats only LMC's part number.
05-04-2013, 11:06 PM | #16 |
I looked on advance autos site and o'reillys site but they don't carry them. I assume LMC is the only carrier
05-05-2013, 08:52 AM | #17 | |
Sources may be a bit more limited, like I said, because that is not a wear-out item. You only need to replace it if it gets damaged (bent), normally you just need the ends.
05-05-2013, 01:37 PM | #18 |
Any auto parts place should have these, I know off road design has some nice beefy ones. I wouldnt buy the lmc ones, I did and they are overpriced junk imo.
05-05-2013, 03:28 PM | #19 |
In the Forgotten far North.
I just replaced items 4-6,10-12 & 17-19 on my '90 3/4ton suburban. While using the pickle fork to seperate the right side tie rod end from the knuckle the socket fell off of shoulder pin. AND I HAD JUST DRIVEN IT BACK FROM WASILLA, AK. 65 MILES AWAY!!!!
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
