Old 05-05-2013, 05:36 PM   #1
dey59
edelbrock spacer
got a 72 sbc, in a 70 gmc. mostly stock maybe rv cam, it has an edlebrock performer intake dual plane and edlebrock 1405 carb. but it has a carb spacer about an inch tall. I got the intake off right now, my question is do I need to put this spacer back in. or can I just bolt the 1405 to the performer with a fiber gasket. this is not a hot rod just trying to make a good dependable daily driver thanks
dey59 is offline   Reply With Quote
Old 05-05-2013, 05:37 PM   #2
Gene
Gene's Avatar
Re: edelbrock spacer
If you dont run it you will experience carb. gas boil. Most Edelbrocks need this.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
Old 05-05-2013, 06:27 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Well said
Tx Firefighter is offline   Reply With Quote
Old 05-05-2013, 10:55 PM   #4
dey59
thanks guys
Old 05-06-2013, 12:44 AM   #5
67c10rustbuket
67c10rustbuket's Avatar
Also an edelbrock air cleaner wont fit directly on an edelbrock carb without a banjo fuel fitting. the out of the box fitting on the carb will interfere with the air cleaner. Atleast all the old ones I had did. The spacer is a good thing for the reason mentioned above.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
