Old 05-05-2013, 05:32 PM   #1
crzo68
crzo68's Avatar
HELP I Screwed UP...I Think?
1) well i got the horn contact kit from chevytruckandcarshop.com as well as other parts... so i put the horn contact kit installed to best of my knowledge but then the horns Worked bUT wont shut off_ so i unplugged horns and but i didn't touch steering wheel so i think the horn was still going off... 2) so i then decide to put on my safety neutral switch...wrong part so put old one back on but lost 1 screw. and after all this the horn ,s.n switch ...the 1972 GMC is dead-... i charged battery ,nothing...then tried to jump start it which then melted my jumping cables but no lights no power nothing ...what did i fry? i thought the horn contact or S N switch etc...but battery started to boil a bit i think....any ideas the truck was perfectly fine until this morning???
crzo68 is offline   Reply With Quote
Old 05-05-2013, 05:35 PM   #2
chevy72blu
chevy72blu's Avatar
Re: HELP I Screwed UP...I Think?
Sounds like you have a serious short somewhere. Start tracking down your power wires and look for where it may be grounding itself
RIP EastSideLowLife
'72 C20 SWB convert. 5 lug, LS1/4l60e
chevy72blu is offline   Reply With Quote
Old 05-05-2013, 05:37 PM   #3
longbed67
longbed67's Avatar
the only thing that would cause that large of ground out would be one of the main power cables or the wire that goes from the alternator to the starter.
Adam
My 1967 C10 - Turbo 250 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=485843
(608) 214-8706
longbed67 is offline   Reply With Quote
Old 05-05-2013, 05:38 PM   #4
DeadheadNM
Carpe manana
DeadheadNM's Avatar
If you followed the LMC Truck diagram for the horn contact assembly it is wrong. Search posts here for the correct order of install. Small fish compared to the other probs but this will alleviate the continuous horn honk at least. Hang in there!
Old 05-05-2013, 05:42 PM   #5
wgr2112
When putting things together, DO NOT overtighten the 3 screws that hold everything in place!
The spring steel must be able to "spring" in order to shutoff the horns!
Really, just make sure they all have a good bite on the threads and call it good.
Made the same mistake!
wgr2112 is offline   Reply With Quote
Old 05-05-2013, 05:44 PM   #6
crzo68
crzo68's Avatar
Actually i just followed off my other GMC. I just put in the contact spring ,tab, cam my 70 is in working order... thanks.
Old 05-05-2013, 05:47 PM   #7
crzo68
crzo68's Avatar
NOTED thanks
Old 05-05-2013, 05:50 PM   #8
crzo68
crzo68's Avatar
Im laughing finally ...thanks for agreeing haha anyway im still lost i un did the horn the SN switch ??? only has 1 screw??? but it worked before hooking it back up???
Old 05-05-2013, 05:52 PM   #9
crzo68
crzo68's Avatar
i thought the horn but still dead
Old 05-05-2013, 05:53 PM   #10
crzo68
crzo68's Avatar
Thanks for all your responses
Old 05-05-2013, 06:26 PM   #11
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
If your horn was stuck on after installing the contact and you just unplugged the horn, the horn relay will still be closed and deplete your battery, even with the horn itself unplugged.
Tx Firefighter is offline   Reply With Quote
Old 05-05-2013, 06:27 PM   #12
john
member #16
john's Avatar
If you just unplugged the horns, your horn relay is still pulling power. You need to unhook your horn kit or unplug the relay until you get the kit figured out.
john is offline   Reply With Quote
Old 05-05-2013, 07:08 PM   #13
SuperC10Tex
SuperC10Tex's Avatar
Well, when you get back to the point of hooking up the horn kit...check out this link http://67-72chevytrucks.com/vboard/s...d.php?t=509147 it might help!!
1970 GMC Sierra Grande CST SWB Fleetside "Texas Touch"
"An intellectual is a man who takes more words than necessary to tell more than he knows"
SuperC10Tex is offline   Reply With Quote
Old 05-05-2013, 07:38 PM   #14
crzo68
crzo68's Avatar
Thank you much
Old 05-05-2013, 07:41 PM   #15
crzo68
crzo68's Avatar
Again thanks it helped and the problem is solved ...hopefully
it killed the battery ...so replaced the battery and the truck started right up
Old 05-05-2013, 07:43 PM   #16
crzo68
crzo68's Avatar
everthing seems ok ,horn beeps good truck runs next thing ...the safety neutral switch whatta ***** that is...
