#6851 |
![]() Join Date: Jun 2012
Re: What did you do to your truck today!
Doing what? Haha
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son ![]() |
#6852 |
Yeah for sure!
Jeff 1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt 1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior |
#6853 |
![]() Join Date: Dec 2012
Well sold my Two Boats
and Won $20 at the Kentucky Derby Family event ![]()
1971 GMC Sierra 1959 GMC 100 |
#6854 |
Tried to unbolt rear springs with no luck. Now they sit soaking in pb blaster. Will find a pipe to go over my breaker bar tomorrow, hopefully they don't break.
70 lwb c-10 |
#6855 |
I got allot done today. I put in new shocks and springs on all 4 corners, and I installed new ece trailing arms, and put a dual exhaust that I bought from lmc. The stance of the truck is just how it should be now, and it sounds good as well.
#6856 |
Bought a slightly used rebuilt engine with double hump heads and a Muncie 4 speed to replace the old tired 42 year old engine in my GMC.
Erik 1969 Chevy K20 6.0L/4L80E/NP205 1971 Chevy C30 Cheyenne Longhorn 454/TH400 1971 GMC C3500 becoming a K3500 dually |
#6857 |
Played with the choke and pulled up on it and got it to idle without stalling. Found a vacuum hose with a 1 inch tear at the end.
#6858 |
Big DaddyV I know the feeling. We got close to an 1.3/4 here. It rained all night real hard.
I dont know which has the most water,pool or yard. |
#6859 |
a little action on the fire wall
#6860 |
Son and I swapped out the valve-body & governor in the 2004R
Also cut out the stock trans cross-member to replace it with an new one to help with clearance. ![]() It was messy but fun non the less.... ![]() Scott
68-SWB, 327, hooker headers, spintec mufflers, disk brake 3.5/5 drop, buddy buckets, 200-4R, 2200 stall, 3.73 12bolt Eaton Posi, ![]() ![]() All my Google Albums |
#6861 |
Pics or it didn't happen.... lol
J. Vess, 6'6", Gearhead, Welder, Fabricator, Nutcase 1955 Chevy Stepside "Dudley" My daily http://www.67-72chevytrucks.com/vboa...d.php?t=760288 1972 Chevy C10, Project "Chevro~Layed out" Nether Storm Build Thread http://67-72chevytrucks.com/vboard/s...23#post6007523 |
#6862 |
I think my yard does... but my basement is catching up.....
#6863 |
Yesterday: Replaced tailgate and upper hatch weatherstipping with a set that I purchased from Franks Pick-M-Up almost 2 years ago, polished the rig and then drove to Alki Beach.
#6864 |
Installed new (to me) '72 tilt column only to be haulted becasue horn cam was broken..so off to the web to order some new one along with horn contact kit and while i was there new item polished stainless tailgate hinges, so ordered a pair..SWEET ! THEN I started replacing nuts and bolts with stainless ones..productive day!
#6865 |
I wire wheeled the underside of my bed, primed it with 2 coats of Rust Bullet, and added 2 more coats of role on bedliner for undercoating and sound.
Mark 71 C10 Cheyenne 12 Aprilia RSV4 |
#6866 |
Finished engine and transmission install after rebuilding this winter. Worked out about 90% of the kinks that come with installing new and different parts... Vortec heads, new carb, new radiator, hoses, and all the Misc stuff. Oh yeah and then there was the heater core that couldn't handle the new install and started puking coolant everywhere. That will be next....
I love the Voodoo cam and the sound that comes with it. Almost wish I went with a little more rough idle cam but this has a ton of power to go along with the new heads. It still had the original motor in it when it came out and I absolutely love having the torque and hp that this truck was meant to have! Drove it for about 2hrs home after getting every broke in. Took the long way home just to enjoy and get it all set.
Thanks, Joe 1972 C10 350 Auto |
#6867 |
Got my vintage license plate project kicked off. Had one set for a passenger car and got a couple more sets cheap off ebay. Gonna paint them all and if they turn out good will sell two sets and use one for myself.
#6868 |
Dude! I can just picture those plates looking like that last picture, right after a bunch of cats in striped jumpsuits took them out of the press at the Huntsville unit 43 years ago!
JK |
#6869 |
You hit the nail on the head. These are the same plates that came with the Huntsville prison rodeo flyer separator sheet on them.
#6870 |
only had the truck for a few weeks now. yesterday i put new visors in (LMC). repainted the glove box door, rear view mirror arm, visor brackets, and the edlebrock air cleaner cover. after the paint dried on the cover i belt sanded the tops of the ribs back to the bare aluminum. than checked the timing and found it 12 deg BTDC which is WAY to far. it should probably be from 4 to 6 maybe 8 at most. then realized the vacuum advance was loose on my MSD cap so first thing this morning i pulled the cap off and tightened it up. then tonight i ordered a 4/6 drop and disc brake conversion kit. i got too excited and paid an extra $93 dollars to get in 2 days. ill be doing this project this weekend hopefully.
'67 2wd LWB 350/4speed. |
#6871 |
___________________________________ Dima 1970 Chevrolet C10 stepside http://67-72chevytrucks.com/vboard/s...d.php?t=569197 |
#6872 |
Lowered the front and added disc brakes. Not finished but had to set the front on the ground to see.
![]() Posted via Mobile Device
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO ![]() Last edited by First c10; 05-06-2013 at 11:02 AM. |
#6873 |
today i had to try and undo the mistakes of the prior owner. the truck is dark blue, originally light blue. the previous owner decided to try and fix some serfice rust by spraying a metalic blue rattle can pain over it that was far from either the original color or the current color. with some steel wool and minineral spirits i was able to get rid of a lot of it. not it just looks like it has patina.
#6874 |
Looked out the window @ 0-Dark:30 and saw it was raining so I drove it to work , nice and sedately in the slow lane @ 65 MPH as the 'tards wizzed & slid by in their hoopty escalades and exploders all crossed up on bald 22" tires going faster in the rain than they do when it's dry....
Seriously , there's no fixing stupid .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH ![]() |
#6875 |
went and got acid to clean the fuel tank and some more primer to finish the tailgate and interior. Now im headed to the basement to sand and prep the tailgate... Woohoo fun fun
