Old 05-06-2013, 09:56 PM   #1
Lou Boffa
Lou Boffa's Avatar
Engine temp sending unit wire
The heat shield around the wire that runs across the top of the valve covers is pretty much shot and crumbling on my '70 C10 350. Anyone know what I can use as a replacement.
Lou Boffa is offline   Reply With Quote
Old 05-06-2013, 09:58 PM   #2
Lee H
Lee H's Avatar
Re: Engine temp sending unit wire
The cover is available from multiple vendors. Best to replace with correct materials. You can use plastic loom but it will deteriorate faster.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 05-06-2013, 09:59 PM   #3
pdawg
I just covered it up with some split loom and it seems to be holding up ok. It doesn't get too much heat so it hasn't been a problem.
pdawg is offline   Reply With Quote
Old 05-06-2013, 10:01 PM   #4
Lou Boffa
Lou Boffa's Avatar
I couldnt locate from Brother's or LMC.
Old 05-06-2013, 10:07 PM   #5
pdawg
I'm in Canada so I'm not sure where you can pick it up - likely an auto parts store or electrical supply.
Old 05-06-2013, 10:13 PM   #6
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
The original place for the temp sending unit is in the drivers side cylinder head. Then it doesn't have to lay on the top of the engine or valve covers.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 05-06-2013, 10:35 PM   #7
pdawg
I actually had one in each cylinder head. When I installed the crate engine I maintained both of them. The drivers side one comes up from the head, across the front of the valve cover, then along the edge if the intake manifold/valve cover to the rear if the engine.
Old 05-06-2013, 10:43 PM   #8
GASoline71
GASoline71's Avatar
Then you spliced the wires together from both sending units?
Seems like overkill to me... not to mention you could clean up the engine compartment without all the extra wire...
Gary
Old 05-07-2013, 09:39 AM   #9
Lou Boffa
Lou Boffa's Avatar
the wire and loom on my engine runs from the sending unit in the block up along the top of the valve cover and under 2 small steel tabs welded onto the cover then back through the fire wall. I'll try the split loom and see how it holds up. Thanks
Old 05-07-2013, 09:43 AM   #10
pdawg
I didn't do any splicing - it came this way from the factory so I wanted to maintain both when I swapped the engine. It really doesn't look messy.
Old 05-07-2013, 10:01 AM   #11
Mr Chevorlet
Rusty Nuts
Mr Chevorlet's Avatar
I bought about 3 feet of it from orilleys a few months ago. They do carry the exact heat cloth loom you are looking for.
(Clever Missouri) Southwest
Larry
Mr Chevrolet
My Build, The Marathon Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=604414
Mr Chevorlet is offline   Reply With Quote
Old 05-07-2013, 10:05 AM   #12
Lou Boffa
Lou Boffa's Avatar
perfect. will do. thanks
Old 05-07-2013, 11:23 AM   #13
MARKDTN
Look in the "Help" section of a parts store. If they don't stock it, they can get it.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
