05-08-2013, 11:03 AM | #551 |
Re: Danny Boy is BAACK! w/ '55 Big Window
Looking Good Dan, like they say if you have to eat a elephant do it one bite at a time!
05-08-2013, 11:08 AM | #552 |
Yes and I have to remember the rust has been "eating" my truck for almost 60 years. So I can't undo all that in an afternoon... but I WANT to! Lol.
Posted via Mobile Device |
05-08-2013, 11:13 AM | #553 |
I'm going to do a frame off on the 64 next winter so I may have to lean on some of your experience's. I'm so glad this forum is just like a great big family!
05-08-2013, 12:32 PM | #554 |
You're right, Indian...most of the time. I always say we're "friends that haven't met yet"
05-08-2013, 01:19 PM | #555 |
Certified Car Nut
05-08-2013, 01:48 PM | #556 |
Bam,
You & I might end up being brothers from differnt mothers cause we already bust each other's ball and have never even met! But eriously, I look forward to talking to some of you guys almost daily and when one of you says, "Hey, good job" it feels good. (I must be pathetically insecure, ha ha!) |
05-08-2013, 02:02 PM | #557 |
you know Dan, I took a look back at the beginning of this thread when you picked up your truck and then look at where you're at now with this project. I just wanted to commend you on doing so much in such a short amount of time. It doesn't even look like the same truck.
Forums such as this is what drives people to keep working on their trucks. When I did the build up on my 72 back in the early 2000's, there were people helping me out from around the globe with technically information. There were a bunch of us that met up in Indianapolis for the Super Chevy Nationals back in 2004. We all stayed at the same hotel, ate at the same places, tail gate partied every night, raced go-karts and made a bunch of life long friendships. And it all came from this forum.
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
05-08-2013, 03:01 PM | #558 | |||
05-08-2013, 06:36 PM | #559 |
yo dan if ya ever make it to vegas ---------
05-09-2013, 07:32 PM | #560 |
I did final fitting/welding/grinding on the passenger side speaker holes today:
Not great after having seen some of the work you guys do but I am proud to say I id it myself. I'll get better as I go along, I'm sure of it. I threw some primer on it just to keep it from flash rusting until I get back to it as it started raining this afternoon. QUESTION: Do most of you guys and girls weld all the spots, then grind everything smooth? Or do you put in a few tacks, grind, tack some more, etc? I ground them all at the end and thought I got too much heat built up. In this case, I could NOT reach behind to hammer & dolly as I went. |
05-09-2013, 08:07 PM | #561 |
looks good
05-09-2013, 09:29 PM | #562 |
Looks great.
05-09-2013, 09:58 PM | #563 |
Thanks you guys, but at best it looks ok. But I appreciate the kind words.
When I do the driver's door I will be even MORE careful with alignment than I already was. |
05-09-2013, 10:33 PM | #564 |
Certified Car Nut
Dan there is never anything wrong with feeling good, especially about your hard work. By the way the patch is looking great man keep up the good work.
05-09-2013, 10:39 PM | #565 |
Bam,
What about WHEN to grind? Seems like its easy to make the metal paper thin (Post #560 above)! In hindsight, I tacked a moment too long. The lack of gas was effecting the weld, but I didn't know it. I was going through the flap disk too fast, so I switched to the thick grinding wheel. Worked better, but caused bluing - so I stopped immediately. Guess I gotta grind as slow as I tack, huh? |
05-10-2013, 12:07 AM | #566 |
The patch came out real nice.
Kim |
05-10-2013, 12:27 PM | #567 | |
Certified Car Nut
Its all about how far you are willing to go. Some people like myself try to use very little to no filler, I try to get the metal that I have access to the back to only need primer as a filler. When I don't have access to the back I even more delicate when I weld in a panel because I know I will have to live with the shrinkage and use filler, so I try to minimize that shrinkage as much as possible. I don't know what equipment you have but this is how I grind welds. I use a cut-off wheel on my 3 inch air grinder to know the bead down and then I use my roloc disc on a air grinder to clean it up and blend the patch in. |
05-10-2013, 02:42 PM | #568 | |
Thanks Bam, this is EXACTLY the advice I was looking for all in one place instead of reading bits & pieces in various threads and trying to surmise what's the best (for me) to do.
EQUIPMENT I have a couple 4" angle grinders - a good Milwaukee one, and a cheapo HF one that has lasted so far. I have cut off disks and thicker grinding type disks. I'm thinking of getting a couple more angle grinders to keep a flap disk and a wire wheel on so I don't have to be changing. I do have a cheapo air angle grinder with HF Rolocs - but since buying I've read those don't last. Have a recommendation for a good brand Roloc disk? I also have a 60 gallon vertical compressor but I haven't run 220v to my garage yet - that is coming later this month/June. In the meantime I have a little Senco compressor I use for tires and nailers, but it can't keep up with the angle grinder. Thanks again for all your advice so far. Best, Dan Quote:
05-10-2013, 03:53 PM | #569 |
Certified Car Nut
Dan I buy the roloc sanding disc in bulk on ebay. I buy 60 or 80 grit. Now remember I said I knock the bead down with a 3 inch cut off wheel on an air grinder. Please don't try that with your electric grind it could be bad for your health. Do the best you can until you get that compressor hooked up. I have used flap disc on electric grinder but you must be careful as you know it can remove a lot of metal. I've also used a flap disc on a variable speed polisher I liked it because I could slow the speed down.lol
05-10-2013, 05:08 PM | #570 | |
Unless you're talking about cutting myself? I ALREADY learned that painful lesson right after I got my truck and cut out an 1/8" thick plate the PO had welded into the bed. Cut the CRAP outta my index finger. Took a long time to heal that one. |
05-10-2013, 05:48 PM | #571 | |
Certified Car Nut
A long time ago I was cutting and got wanted to help it along and the dang thing exploded in my hand. Well 15 stitches later I learned my lesson. I was just thankful it was my hand and not my eyes. Last edited by Kabwe; 05-10-2013 at 06:22 PM. |
05-10-2013, 06:14 PM | #572 |
I also use the cutoff wheels on the die grinder in tight spots where the wheel might get stuck and break or kick back. The die grinder will just stop where the electric grinder won't.
05-10-2013, 08:43 PM | #573 |
Ok, I see what you guys are talking about. There's a sort of default fail safe with the air die grinder because it will bog down. Having not really used mine yet, I didn't think of that.
On the electric grinder, it seems that the thicker grinding disc would be "safer" in that it won't slice quite as quickly if it inadvertently goes against your glove (or elsewhere/leg) than the thinner, sharper cutting disc. But I'm probably quibbling over milliseconds anyway. |
05-29-2013, 12:14 PM | #574 |
your build thread has been a bit idle so I thought I'd check in and see how things are going Dan
05-29-2013, 12:24 PM | #575 |
Thanks for noticing.
You're right. I was on a roll and then I got sidetracked prepping for a camping. But I'm back now (again). Still a few post vacation things to do - clean/wash the camper and truck, make some repairs, etc but I should be back on the truck's door panel repairs soon so I can FINALLY!!!! paint the door interiors then get the new door weatherstripping on and stop the terrible rattling. I rarely drive the '55 for that reason & the lack of a dual master cylinder that has me being a "Nervous Nellie" - the stock single MC only worked fine for 60 years, lol. |
