Old 05-06-2013, 04:49 PM   #1
asolde
asolde's Avatar
Stock speaker
I have seen two different styles of mounting stock speakers. I believe the yellow dash is correct?
asolde is offline   Reply With Quote
Old 05-06-2013, 06:01 PM   #2
Mint68
Mint68's Avatar
Re: Stock speaker
That is how mine was, the yellow that is.
Mint68 is offline   Reply With Quote
Old 05-06-2013, 06:07 PM   #3
blazerboy72
Re: Stock speaker
One of mine was like the orange one and the other was mounted in the dash behind the radio.
blazerboy72 is offline   Reply With Quote
Old 05-06-2013, 06:17 PM   #4
Mint68
Mint68's Avatar
Re: Stock speaker
Here is a pic from mine, not the best, but may help.
Old 05-06-2013, 06:21 PM   #5
Mint68
Mint68's Avatar
Re: Stock speaker
I don't think I have seen a blazer with the speaker grill in the dash behind the radio before. My pic is from a 1970 that was original and I believe it is mounted as it left the factory.
Old 05-06-2013, 06:44 PM   #6
briank
Re: Stock speaker
My 69 is off to the left and nothing had been messed with.
briank is offline   Reply With Quote
Old 05-06-2013, 07:27 PM   #7
asolde
asolde's Avatar
Re: Stock speaker
Thanks guys. The brackets used to mount the speaker off to the left have nuts welded to them and are mounted in behind the dash panel correct? I am missing one of those brackets. Is there a part number for them or a aftermarket one? I want to mount mine like the factory had it.
Old 05-06-2013, 10:12 PM   #8
Mint68
Mint68's Avatar
Re: Stock speaker
I believe that is how they're mounted, but its been a long time since I've messed with one. I would think you would have better luck duplicating the bracket you have on your own, rather than finding one through a part number. I don't believe there is an aftermarket one available, and they a sort of hard to come by used.
Old 05-06-2013, 10:54 PM   #9
1949gmc
Re: Stock speaker
The yellow dash picture is of my old dash and it was 100% original. That's where the General mounted them in 1971.
1949gmc is offline   Reply With Quote
Old 05-08-2013, 08:15 PM   #10
themb2g
Re: Stock speaker
Mine was mounted under the dash behind the radio/ heater controls.
Check out my build: 1972 LQ4 Swap
http://67-72chevytrucks.com/vboard/s...=1#post5427693
themb2g is offline   Reply With Quote
Old 05-08-2013, 10:41 PM   #11
69-72
69-72's Avatar
Re: Stock speaker
Oh great now I am gonna have to put mine off center. I am not sure that my passengers will appreciate me hogging all of the music.
1969 Chevy Custom Camper 3/4 ton Rust free survivor
1972 Chevy Blazer CST 4x4 Almost Rust free survivor
1972 GMC Jimmy 2wd Undergoing surgery
69-72 is offline   Reply With Quote
Old 05-11-2013, 03:19 AM   #12
BBrendal
Recalculating.....
BBrendal's Avatar
Re: Stock speaker
My Blazer has the grill on top of the dash behind the radio. It was a May of 72 build dont know if that makes a difference.
Brian - (BBrendal)
1969 Chevy Camaro Z28
2004 GMC Yukon (The truck that pulls the car trailer)
1972 Chevy Blazer CST #2 (Finished and sold!)
Blazer build link...
http://s1213.photobucket.com/albums/...rendal/Blazer/
BBrendal is offline   Reply With Quote
Old 05-11-2013, 07:18 AM   #13
2003 silverado
2003 silverado's Avatar
Re: Stock speaker
History does repeat its self Check out this tread
http://67-72chevytrucks.com/vboard/s...d.php?t=522444
!972 K5 Blazer,Highlander,A/C a twin to the one I Had
1972 K/5 Blazer CST Highlander 15YR project
2003 Silverado Crew 2500HD (Daily driver)
1997 Ford focus (Beater)
2003 ford Taurus (student)
2014 Ford Fusion HYB (wife)
2003 Jetta ( Student)
2003 silverado is offline   Reply With Quote
Old 07-28-2013, 06:47 PM   #14
2003 silverado
Re: Stock speaker
TTT for pete
Old 07-28-2013, 08:23 PM   #15
fast eddie1968
Re: Stock speaker
The 72 I bought for parts had the speaker in the dash behind the radio and the dash pad date was late may 72 .
fast eddie1968 is offline   Reply With Quote
Old 07-28-2013, 08:37 PM   #16
BBrendal
Recalculating.....
BBrendal's Avatar
Re: Stock speaker
Both my current blazers have a may 72 build date with a single wall top and in dash speakers. My first 72 blazer I had had under dash double wall top but I'm not sure of build date. That one had CA emissions too. Don't know if this means anything.
Brian - (BBrendal)
Old 07-28-2013, 08:52 PM   #17
Mike C
Mike C's Avatar
Re: Stock speaker
My '72 Jimmy has the speaker in the dash and the parts '72 Blazer I had also had the in-dash speaker.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 07-29-2013, 12:32 AM   #18
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Stock speaker
Originally Posted by 2003 silverado View Post
TTT for pete
Thanks Dave!
So was the under dash speaker possible in any year of a 1st gen K5 or was this obsolete by 72 with all getting an in dash speaker that year?
Old 07-29-2013, 07:29 AM   #19
2003 silverado
Re: Stock speaker
I believe they were using up old dashes and grabed what ever one they had left Last YR thing
Old 07-29-2013, 10:29 AM   #20
briank
Re: Stock speaker
There was just a 1972 k5 on ebay that had the speaker mounted directly below the heater controls.
Old 07-29-2013, 10:35 AM   #21
jaros44sr
jaros44sr's Avatar
Re: Stock speaker
GM was probably worried about getting the speaker wet with the top removed, so they mounted it under dash for somewhat more weather protection. And it probably was mounted to the left if the truck was equipped with air. Just an uneducated guess, since some mounts had the nuts welded to the mount
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 07-29-2013, 10:59 AM   #22
skorpioskorpio
Re: Stock speaker
My '70 Jimmy had the speaker mounted in the front of the center console, I'm quite sure it wasn't original but it was very well done and even had a grill that matched the contour of the console. The grill looked like the same type as the underdash grill but was thinned in the middle and thicker just towards the ends so the grill laid flat across the front and had no gaps against the console.
skorpioskorpio is offline   Reply With Quote
Old 07-29-2013, 01:55 PM   #23
Sandemonium
Proud owner of a 55.1 AD
Sandemonium's Avatar
Re: Stock speaker
My '72 Jimmy is similar to the orange dash. No speaker opening on top of dash. My '72 has A/C and was a 4-speed truck with a 350 V8.
Sandemonium is offline   Reply With Quote
Old 07-29-2013, 03:14 PM   #24
pound41
Re: Stock speaker
Personal belief is the blazers with the speaker in the top of the dash are truck cowls. My 69 camaro had a matching numbers block with an odd casting number. I started researching and found it listed to be known in 8 camaros. In my research I found where it was documented by GM line workers said when we ran out of a part. We didn't stop the line we we grab a similar part. Noted the changes and kept the line moving. I doubt GM used to separate cowls for blazers.
pound41 is offline   Reply With Quote
Old 07-29-2013, 04:23 PM   #25
tjsblazer
tjsblazer's Avatar
Re: Stock speaker
My '72 does NOT have the speaker hole in the top of the dash. It left the factory with an AM radio, base model (non CST).
Jeff.
'72 Blazer K5
"Camshaft opinions are like belly buttons; everyone has one and no two are alike"
My Blazer Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=626752
My Engine Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=637336
tjsblazer is offline   Reply With Quote
