05-08-2013, 08:04 PM | #1 |
L88 hood on our trucks.
Has anyone made or seen an l88 hood on our trucks? I'm thinking of fabbing one up but wonder how it will look.
Rob 1971 c10 - ground up in progress Tripp's Speed Shop Build - http://67-72chevytrucks.com/vboard/s...d.php?t=589750 |
05-08-2013, 08:19 PM | #2 |
Re: L88 hood on our trucks.
my bet is will look great!!!
05-08-2013, 08:32 PM | #3 |
Cluster King
I think it may look ok if you figure out what to do in the middle. Since the L-88 scoop and the hood body line do not match. It might take some trail and error to get it looking right.
05-08-2013, 08:40 PM | #4 |
While it could look pretty good a few things come to mind.
Are you planning on fabbing it from scratch or using a vendor scoop and attaching it? If so get the dimensions and lay it out with tape. Are you planning on making it a true cowl induction hood and hot air extraction vent or is it to be just a bump?
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
05-08-2013, 08:57 PM | #5 | |
Im planning on fabbing it from scratch so I can match and remove certain body lines. Im not sure how functional I will make it. I'm a long way away from body work but just lining up my ducks to see where Im taking my build.
05-08-2013, 10:26 PM | #6 |
Proprietor of Dale's Corner
hey Rob, I had one on a camaro and they are water catchers that gets to be a pain
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
05-08-2013, 10:41 PM | #7 | |
