Old 05-09-2013, 07:24 PM   #1
t5noel
Re: Control Arm Bushing replacement
I used an air hammer, it was ugly and difficult to replace the bushings. I'll never do it again. If I can buy new control arms already assembled I will go that route.
t5noel is offline   Reply With Quote
Old 05-10-2013, 02:14 AM   #2
74 stepside
74 stepside's Avatar
What I do is weld in some steel on the bottom of the arms to give it more strength before using a press. Plus it also helps keep the arms from getting bent when they hit the ground on lowered trucks.
74 stepside is offline   Reply With Quote
Old 05-10-2013, 06:27 AM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Very smart idea. That would sure help with the crushing issue when using a press.
Tx Firefighter is offline   Reply With Quote
Old 05-10-2013, 08:18 AM   #4
SigFTW
Good ideal!
SigFTW is offline   Reply With Quote
Old 05-13-2013, 08:11 PM   #5
bluex
bluex's Avatar
You guys think $75 is a fair price to have both arms plated up like this? Dropped mine off to have them done today. I would do it, but the lowers are to big to sneak into work an i have no welder at home yet....
bluex is offline   Reply With Quote
Old 05-21-2013, 08:55 PM   #6
74 stepside
I dont think thats too bad. Most fab shops charge on average $75 hr.
Old 05-22-2013, 01:57 AM   #7
bluex
bluex's Avatar
Overall I'm happy with it, they could have done some clean up, but with a one day turn around I'm not complaining...
Slowly but surely I'm getting mine ready to go back together. Just have the lowers to clean paint an put new bushings in...
I hope to finish up next weekend....
Old 05-22-2013, 08:20 AM   #8
SigFTW
looking good!
Old 08-05-2013, 11:11 PM   #9
solidaxel
solidaxel's Avatar
Well is everything finished up ?
Did you have any surprises with the install?
How much do you have invested in all the parts without the welding fab work.
I am just starting on my tare down of my 78, and I did not budget anything for the front suspension replacement, but everything is staring at me, and it says to REPLACE moving parts!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 08-05-2013, 11:25 PM   #10
bluex
bluex's Avatar
Nope no surprises and here is a quote from my somewhat build thread on what everything cost. I believe this is close, but I have had the front end parts for a few years just waiting on the time to do the work so I might be off a bit on the prices.
Flip kit only in the rear ( djm-$85), with new kyb gr2 shocks.
The front is western chassis 2.5" spindles an one coil cut off the spring. I don't remember what the spindles cost, i bought them in 1998.
All the front wear parts are new, upper/lower ball joints, inner/outer tie rods, pitman, idler energy suspension black bushings (about $40), edelbrock solid tie rod adjusters (5252-$35 iirc), an also kyb gr2 shocks (about $100 for the set f and r)
All the moog stuff will run you about $350-400 depending on where you buy it. Another $75 for the fab work on the lower arms an about $25 worth of paint.
If you want to read more or see pics of it finished just click the link in my sig....
An now that I look at that list again I left out the offset cross shafts for the uppers at $30 or so per side. So thats another $60 or so.
If you have any questions shoot me a PM, it really wasnt all that hard and I did the bushings myself in the garage..
