Old 05-11-2013, 11:04 AM   #1
jmking9
jmking9's Avatar
Re: Installing AAW kit-Alternator Question
Thanks for the responses. It looks like the SI in the pic that VetteVet posted will plug in to the AAW kit with no problems. That one sould be fine since my truck is mostly stock and has no power add ons. Correct?
My next question is about the factory gauges. Its my understanding from what ive read that the original gauge is an ammeter and it wont work with this setup. Am I understanding that correctly? If so, what should I do for a gauge? I was hoping to keep my gauges all original since I paid a small fortune for the restored ones Im using.
Ive built this truck from the ground up, and Im finding out that my wiring knowledge is weak. So I appreciate the guidance.
1970 SWB Build
jmking9 is offline   Reply With Quote
Old 05-11-2013, 09:19 PM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Read my posts in this thread especially no.10 and you can see that the conversion is easy and the ammeter gauge will work if the fuses in the wires to it are good. The two diagrams in post 10 show these wires and fuses are in the circuits but not in the truck harness. If you decide to go with the SI alternator it will bolt right into your harness but get the later 12 SI shown below. It cools better and puts out more amps. I would rather see you get the newer style CS which will bolt in and can be wired in rather easily with the information in this thread.
.........http://67-72chevytrucks.com/vboard/s...d.php?t=567472
This is the 10 SI and 12 SI alternators The 12 SI was used in the 1980s Camaros.
Here's the adapter plug that you can use in your harness to go to the CS alternator and I think it might have the resistor in it already.
If you have any trouble make a thread in the electrical section and we'll fix you up.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
