Old 05-10-2013, 09:27 PM   #1
JAG66
Behind the seat rear wall ideas?
In all my square bodies, I've had to re-do behind the rear seat because the cardboard tray was always tired looking or missing leaving an unfinished look. I still have the factory speaker mounts and grills, but need to buy new 4 X 10 speakers.
Do I carpet everything, build a durable tray, or just replace the cardboard tray?
Please provide some ideas and pictures on how to finish off that space behind the seats to give it a nice finished look.
JAG66 is offline   Reply With Quote
Old 05-10-2013, 09:59 PM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Behind the seat rear wall ideas?
Cover entirely with fuzzy sided Velcro then proceed to make pocketswith Velcro backing . Bam modular tool tray or whatever you do
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 05-10-2013, 10:45 PM   #3
durty harry
durty harry's Avatar
Masonite cut to fit make my speaker boxes and covered with carpet
Scott
82 step side aka " Bouncy "
73 GMC
Long bed Vortec 5.7
durty harry is offline   Reply With Quote
Old 05-10-2013, 11:04 PM   #4
tucsonjwt
I built speaker boxes out of MDF and painted them black - tucked into the cab corners. Then I built a custom plywood (with solid wood in some places) triangular shelf to fit my stuff. I wanted to be able to put a 4 foot level across the top and not have it get banged around. I finished it in a medium oak (I think) and then put strips of tool box rubber liner on the shelves. It holds a cheap set of emergency sockets (I actually used them out on the road once), a bottle jack, etc. I had the materials (mostly) so it was not very expensive to build.
tucsonjwt is offline   Reply With Quote
Old 05-11-2013, 03:14 AM   #5
INSIDIOUS '86
That's neato.
Old 05-11-2013, 04:15 AM   #6
andrewmp6
I like that shelf system you made.
Old 05-11-2013, 06:49 AM   #7
bigblock73
yeller
bigblock73's Avatar
Mine.
bigblock73 is offline   Reply With Quote
Old 05-11-2013, 11:25 AM   #8
88Jimmy4x4
88Jimmy4x4's Avatar
heres mine, carpet held on by velcro just like bedrugs use
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 05-11-2013, 11:30 AM   #9
76stepsidechevy
Due to someone glueing shag carpet all over the inside of my 76 with construction adhesive I yanked it all out and put some light gray speaker box type carpet back up. I ended up just glueing it all to the steel with 3M 77, it stretched nicely and followed all the contours of the roof and back of the cab with no wrinkles. Also, If you're going to stick with the 4x10s and not use 6x9s I'd recomend the kenwoods.
76stepsidechevy is offline   Reply With Quote
Old 05-11-2013, 11:40 AM   #10
JMac11
JMac11's Avatar
88Jimmy, what are those seats out of???
JMac11 is offline   Reply With Quote
Old 05-11-2013, 11:49 AM   #11
88Jimmy4x4
88Jimmy4x4's Avatar
Those are new procar seats from summit, they sell the brackets and everything for our trucks that use stock mtg holes just have to drill one hole for inside front mount
1991 GMC Jimmy 4x4
