Old 04-27-2013, 10:43 AM   #1
sodly
sodly's Avatar
Fuel Tank Delete???
Has anyone ever heard of a "fuel tank delete" option for camper trucks? I just heard of this on Fords but don't know if it's legit. My 66 Custom Camper did not have a gas tank behind the seat but has two saddle tanks installed instead. I always presumed that the main tank was removed by the owner but I just wondered if there was such a thing as ordering a truck without a fuel tank. Anyone ever heard of this?
Here's the truck that got me wondering about this possibility: http://cgi.ebay.com/ebaymotors/ws/eB...#ht_500wt_1182
sodly is offline   Reply With Quote
Old 04-27-2013, 02:14 PM   #2
oakstcustomz
oakstcustomz's Avatar
Re: Fuel Tank Delete???
its not a 60-66 but i pulled a 350 and th400 from a 69 C-30 camper and it had a "gas cap" that was bolted on the backside so it looked like there was a gas tank behind the seat..... i swooped that for my 65 since i no longer have a tank there......let me see if i can dig up some pics. the C-30 had bucket seats and you could walk into the camper through the cab! should have kept the buckets!!!
1965 Chevy C-20 slammed 292 L6 TH400
1967 Chevy C-20 on 91 suburban frame project(wife's)
1972 Chevy K-20 Mild 350/th350/np2o5 dd
1952 Ford Customline 2door kustom project
1967 Cadillac Superior Hearse (wife's)
1998 GMC Saffari (wife's dd)
oakstcustomz is offline   Reply With Quote
Old 04-27-2013, 02:49 PM   #3
sodly
sodly's Avatar
That's how mine is. The cap is bolted down to look like the behind-the-seat tank is in place. I just wonder who did it. Could it be a factory item? I suspect not.
Old 04-28-2013, 05:50 AM   #4
rideblue00
rideblue00's Avatar
Its possible thats factory. I haven't seen much talk about campers. Give it awhile and bump the thread every so often. Post some pics. Inside and out. I think you could order a auxiliary fuel tank.
rideblue00 is offline   Reply With Quote
Old 05-11-2013, 11:51 PM   #5
HOTFUN
HOTFUN's Avatar
I would bet the tank was taken out by the camper conversion company who installed the dual tanks. Check the glove box option label and if it had some special tank delete it would surely be listed there but I don't see anyway that would be possible since it would have no way to drive out of the assembly line or loaded and unloaded to delivery point. Totally impossible for assembly line process. My C30 C38 chassis had started out a dually cab chassis and the camper outfit took the tank out cut the tank mount straps and holder flush at the floor and cut access hole in the cab back panel a crawl space about 3 by 3 opening into the cab over camper. The original gas cap also was bolted on to the filler neck and slid all the way against the rubber tank grommet.
'66 CST BBW swb fleet 327 fac ac
'67 CST 4x4 swb 327 factory #'s V8 stepside project
'72 Cheyenne K20 50k original
'72 CST Blazer K5 owned 30+yrs
'73 Sierra swb 4x4
'74 Cheyenne Super swb w/16k actual
'71 & 72 Cheyenne K10 4x4 swb's
'70 426 HEMICUDA conv SHAKER 4 sp Dana 60
'60 Impala conv 3rd owner
'72 GMC K2500 4x4
'59 Apache CST BBW fleetside swb 283
'73 ElCamino SS LS1 T56 true SS bucket tach
'76 ElCamino SS 52k survivor
'87 Grand National 41k True 2nd to last built in 1987.
'86 K30 454 SRW fleetside CA since new
'88 Trans Am GTA 39k bought new
2018 DEMON plum crazy @ 840HP! "Need for speed"
HOTFUN is offline   Reply With Quote
Old 05-12-2013, 12:31 AM   #6
HOTFUN
HOTFUN's Avatar
This is what it looked like after I drug it home from Kansas. Factory air (probably a camper company installed GM ac kit) with 327 and powerglide, ps and pb, radio and tinted glass and 5.13 gears. After I stripped the racoon invested camper off to a bare cab chassis again and got it running, the powerglide would shift to drive at 10 mph with those stump puller gears. I bet top speed was 55 mph for most of its 67k miles.
Sorry about the pictures this is all I could find as I lost my hard drive last winter and most of my pictures could not be restored.
'73 Sierra swb 4x4
'72 GMC K2500 4x4
Old 05-12-2013, 08:49 AM   #7
tincan1966
tincan1966's Avatar
I've noticed on some of my wiring diagrams, and option for "cab or chassis fuel tank"
That would tell me that GM might have shipped some as tank delete or chassis type for the campers.
Would be interesting to know the option code for that....
tincan1966 is offline   Reply With Quote
Old 05-12-2013, 02:28 PM   #8
sodly
sodly's Avatar
I agree, HOTFUN. I think it was probably taken out when the conversion was made. Does anyone still run their saddle tanks? I pulled one of mine out to look at it and it's quite a nifty little design. Quite the complex shape. They hang from the bed floor from two large bolts that run through the tank, top to bottom, inside hollow tubes in each tank.
WANTED:
* 60-66 Chevy and GMC FACTORY PHOTOGRAPHY (scans) of pickups and carryalls.
Custom Camper Club-- Own a 65-66 Custom Camper? Join us at: http://67-72chevytrucks.com/vboard/g...hp?groupid=117
