Old 05-12-2013, 12:36 PM   #1
low82c10
rear end question
i tried looking on here for guys who have done a LS swap with the problem i think i have. im sure the 82 c10 i just did the swap on has a stock rear end. i got a 5.3/4l60e it seems like on the freeway i am at a really high RPM i know it shifts into every gear i dont have my tac hooked up yet but what kinda gears do i need to look into getting?
low82c10 is offline   Reply With Quote
Old 05-12-2013, 01:01 PM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: rear end question
I would opt for 3.42 gears. 3.73 if you do minor weight towing frequently.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 05-12-2013, 01:37 PM   #3
low82c10
i dont really plan on towing anything i don't own anything to tow, doesn't mean i wont later down the road. im just worried more about getting on the highway and coasting like the motor/trans would in the stock truck it came from not have to worry am i going to blow something up
Old 05-12-2013, 11:41 PM   #4
Blackpony
Blackpony's Avatar
3.42 would be a good gear selection.
Blackpony is offline   Reply With Quote
Old 05-13-2013, 11:19 AM   #5
gchemist
gchemist's Avatar
3.42 gears are ideal then. My 96 Jimmy tows well with a 4.3, 4L60E and 3.42 gears. Even with 29" tall tires. RPMs with 29" tall tires is ~2000-2100 RPMs. Perfect for cruising 70 MPH.
Old 05-14-2013, 11:36 PM   #6
low82c10
thanks guys, what rear end will work for my truck as far as if i want to find a 12 bolt and maybe a posi? can those be found in a junk yard? from maybe a suburban ?
Old 05-15-2013, 08:19 AM   #7
gchemist
gchemist's Avatar
I run a '77 12 bolt in my truck. Gears are 3.08's. High gears but tires are on the small side. Towing definatly sucks with any amount of good weight. I can't complain of 18.5 MPG at 70!!
You will not find 3.42 in a 12 bolt. You'll have to add them. Common gears are 3.08s or 3.73 gears.
Old 05-15-2013, 08:56 AM   #8
naphtali5725
naphtali5725's Avatar
what transmission are you running? I have a 10 bolt with 3.08's and i'll be running a TH400... what are your rpm's at 70mph?
My build thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=515829
Disabled Veteran
82nd Airborne Division
Operations: Desert Shield, Desert Storm, and Uphold Democracy
naphtali5725 is offline   Reply With Quote
Old 05-15-2013, 10:01 AM   #9
gchemist
gchemist's Avatar
I run a custom built 700R4. 255/60R15 tires. RPM at 70 = 1950
Old 05-16-2013, 12:24 PM   #10
Tucson38
Always a tough call on differential ratios, economy vs performance. Too bad there wasn't a 2-speed differential. That would be handy.
Tucson38 is offline   Reply With Quote
Old 05-18-2013, 04:40 PM   #11
low82c10
whats the deal with 10 bolt or 12 bolt? any difference? other then bolts?>
Old 05-18-2013, 07:13 PM   #12
wraprail
wraprail's Avatar
You say you are at really high rpm? That makes no sence at all cuz you probley have 3.08 ratio right now which would give you really low rpms.
So you must not be shifting into OD
wraprail is offline   Reply With Quote
Old 05-19-2013, 09:40 AM   #13
donut
donut's Avatar
Hook up the tach, then see what you have. You may already be in the "sweet spot".
I know my '86 is close enough that a gear change/OD is not in it's future.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
