Old 05-13-2013, 09:44 PM   #11
1BadAction
1BadAction's Avatar
Re: 7K 73-87 tachs
Originally Posted by MalibuSSwagon View Post
LMC lists the small fuel gauge as only fitting up to 1980, but the picture shows they are both 81-87 styles.
Items # 5 & 6. Its easier to see in the print catalog.
Also, not 100% those would bolt into a standard cluster case, but it does appear the mounts are the same as a clock. So if a clock mounts in any cluster, then so will the LMC fuel gauge.
As for wiring, its simple enough to solder 3 wires to the printed circuit traces and run them across the cluster to the fuel gauge.
I'm leaning toward going exactly this way. I can make it completely factory looking, then use my laptop for data monitoring only when I need it...
2010 Basalt Black Porsche Cayenne GTS - Daily driver
1991 2500 Suburban, Black - 454/80E tow monster, soon to go under the knife... Again.
1979 16' Action Marine/"Johnny Cash" Merc Bridgeport Champ Motor - Metalflake Maniac
1BadAction is offline   Reply With Quote
