Old 05-13-2013, 11:13 PM   #701
coulter
coulter's Avatar
Re: intro + 66 black bagged long fleet
Thanx man!! You and jdoisher and a few others got me wishin i would have pancaked my front crossmember. Its really cool how everybody feeds off each others ideas
bagged 66 longbed build
http://67-72chevytrucks.com/vboard/s...d.php?t=449548
my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918
coulter is offline   Reply With Quote
Old 05-13-2013, 11:14 PM   #702
coulter
coulter's Avatar
Old 05-14-2013, 09:10 AM   #703
jdoisher
jdoisher's Avatar
Judging by the fact that your not afraid to redo anything, I say go for it!! I was able to keep every thing as it was, I had to relocate my air line and move my upper shock hole up one inch!! Once you get the motor out and clip off you can have it done in no time!!! I say do it!!
Jason
http://67-72chevytrucks.com/vboard/s...d.php?t=531177
Maggie's truck!
jdoisher is offline   Reply With Quote
Old 05-14-2013, 10:41 PM   #704
coulter
coulter's Avatar
I really want to but im gonna wait till after i drive it a while and have the money to build.a 496 out of a spare block i have. This is just phase 1 of this build. If i keep it i plan on tearing it back down after i drive it for a while to build a motor. Powder coat everything and do all the body work with a glossy black paint job. Since this was my first build i didnt wanna go all out with the paint on the frame and stuff cause i knew i would need to change things like i have
Old 05-15-2013, 08:00 PM   #705
Jmorales3181
Jmorales3181's Avatar
Thanks you. Yeah I hear you man. The more I think about it I may have gone a little overboard on the painting for my first build but since I paint cars for a living it won't be a big deal to repaint some things if need be
My frame Layin 63 short bed project
http://67-72chevytrucks.com/vboard/s...d.php?t=551353
Jmorales3181 is offline   Reply With Quote
Old 05-16-2013, 01:26 AM   #706
coulter
coulter's Avatar
ya but i would cry if i had to mess up that pretty paint!!!! lmao
Old 05-16-2013, 01:48 AM   #707
Bazooka
Keepin it old school
Bazooka's Avatar
You gotta start making two of everything. One for you and one for me haha
Nice job on those rear arms.
Bazooka is offline   Reply With Quote
Old 05-20-2013, 05:17 PM   #708
coulter
coulter's Avatar
haha i wish it were that easy
thanx man!!!
i got some updates today.. got one side of my exhaust pretty much all fitted and tacked together.. gotta make some more hangers then do alot of welding.. i made some pie cuts around the tranny crossmember to make it clear.. ill take some better pics of that when i go to weld it up.. was hard to get a good shot from under the truck
the exhaust is prolly gonna be way too loud but im gonna try it out and see how i like it.. i can always add more mufflers under the cab.
also i got a question?? since there really insnt room under the cab i thought about adding an H pipe right after where the the exhaust comes through the rear crossmember.. would i benifit much for doing this or is it a bad idea??
Old 05-20-2013, 05:22 PM   #709
coulter
coulter's Avatar
also u can see i took my trailing arm brackets off my rear crossmember. im gonna try to get them modifyed tonight
Old 05-20-2013, 05:22 PM   #710
Jmorales3181
Nice job buddy! almost ready to fire up? ive been waiting patiently!might as well pull the front xmember down and chop it up while your at it for some ground clearance maybe this will help....
Old 05-20-2013, 05:25 PM   #711
coulter
coulter's Avatar
man thats pretty!!! ya im really tempted!! im running 2" drop spindles. i would like to be able to use stock ones like you are.. i bet ur ground clearance is way better than mine in the front.. and it goes lower!!! lol
Old 05-20-2013, 08:05 PM   #712
daverod
SSN 706
daverod's Avatar
Nice work on the exhaust. I have to do the same thing to my 66. That cross member makes me want to go tear mine out.
daverod is offline   Reply With Quote
Old 05-21-2013, 07:56 AM   #713
clemdaddy
clemdaddy's Avatar
good work man... closing in on a driver.
clemdaddy is offline   Reply With Quote
Old 05-21-2013, 11:22 AM   #714
Bomp
Bomp's Avatar
When I added my cross over pipe (White '67 Camaro behind shop) the exhaust note did seem to be a little less loud.
Bomp is offline   Reply With Quote
Old 06-02-2013, 06:03 AM   #715
coulter
coulter's Avatar
thanx ya he did a killer job on that crossmember
thanx man!!! ya im getting pretty excited!! i would love to be able to cruise it to one of ur bbq's this year
ive been reading alot about it and im not totally sure if mine is gonna help me much.. i know they need to be as close to the motor as possible but im still gonna go for it
i did get a lil farther this weekend.. there first couple pics are of the mods i did to the trailing arm brackets.. since i set up my bag brackets with those huge lowering blocks the bags were bottoming out before going all the way down with the smaller lowering blocks (another nooby mistake learned the hard way ). so i made the holes on the trailing arm brackets about 1 1/2 lower than stock. it hangs just a lil bit below my crossmember but it wont be a problem because i wont be going low enough to touch that anyway since my front wont go that low.. im just gonna level it with some bump stops so it never drags anything in the rear.
also got my exhaust most of the way done.. just need to finish 1 more hanger, finish my H pipe and do all the final welding.. also gonna need to reroute the air line for the front bags now but thats no biggie.
its hard to tell from the pics but ive got about 3/4 inch of clearance between my exhaust and my tranny crossmember. btw all the exhaust under the cab will get heat wrapped to keep my fuel line as cool as possible
anyway enough blabbing and on with the pics
Old 06-02-2013, 06:05 AM   #716
coulter
coulter's Avatar
and ya i know this exhaust is gonna be a lil overkill being 3 inch on a basically stock 454 but one day i plan to build a pretty nasty 496 so i dont wanna have to upgrade that later on
Old 06-02-2013, 07:26 AM   #717
mark 66
looks like careful planning is paying off. there is alot of stuff going on in that small area.definitely think routing the exhaust thru the trailing arm front bracket is the way to go. no ground clearance issues.3 inch ehaust is HUGE. nice job
mark 66 is offline   Reply With Quote
Old 06-02-2013, 12:08 PM   #718
Jmorales3181
Looking great man! I'm ready to hear it start up!!!
I bet it's going to sound mean!!!!
Old 06-03-2013, 08:12 AM   #719
coulter
coulter's Avatar
Thanx guys!!! I got my crossover pipe done. Just gotta do some final welding and the exhaust will be pretty much done
Old 06-03-2013, 12:28 PM   #720
Bomp
Bomp's Avatar
That is some twisted wicked exhaust!
Dig it
Old 06-04-2013, 02:04 AM   #721
coulter
coulter's Avatar
Ya its pretty crazy lookin and not normal so i knew you would like it
Old 06-04-2013, 12:29 PM   #722
Bazooka
Bazooka's Avatar
never seen anyone do their exhaust like that. Its cool looking!
Old 06-07-2013, 05:19 PM   #723
coulter
coulter's Avatar
thanx Bazooka!!
i got a chance to do a little more work. im waiting on some header wrap and some flex couplings. then i will finally be able to finish the exhaust up.
besides that i got the holes drilled for the crossover pipe, and all the welding done today.
i noticed that some H pipes have a smaller hole than the diameter of pipe. I had a hole saw to cut a hole for a door knob so i just used that.. i believe it was 1 3/4"
anyway on with the pics
Old 06-07-2013, 05:36 PM   #724
likaroc13
Rollin' Old Skool
Nice fab work on the exhaust! Just curious to know if the smaller diameter hole in the H-pipe affects anything much (I'm no exhaust expert, haha)?
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 06-07-2013, 05:50 PM   #725
coulter
coulter's Avatar
thanx man!
im really not sure.. i think its just so the pressures can equalize without too much exhaust getting trapped in the crossover pipe but thats just a guess.
