I have a 74 short bed &want to drop it for fun but still need to use it as a real truck will bags carry the load or should I go with drop spindles ?
TKS KC ![]() Posted via Mobile Device Posted via Mobile Device
48 GMC Burb 51 Chevy AD 3100/C 4 byShannon 74 Chevy P 10 48 Double Duty 04 SS Burb 01 Springer HD |
Re: Help for the timid..bag it ?
Yes air bags can handle weight fine every semi on the road has them on the rear suspension.One of my friends has a bagged s10 and he hauls his atv in the bed all the time no problems.
![]() Join Date: Mar 2012
With bags you can haul more than you can with your stock springs. A properly installed air bag suspension is much better than a stock setup in regards to towing and load carrying.
#teamlongbed "I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb 1978 Chevy shop truck - static 6/8" 1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497 |
You don't need drop spindles on your 74 unless you want to lay it on the ground. You can get 4-5" drop in front just with bolt in bag plates and short lower cups. Anymore than 4-5" drop without spindles and you will run into problems with alignment.
I prefer the bags due to the better ride, and the adjustability aspect is a huge plus in my opinion. You can bag without spindles, but I would recommend them.
Let us know if we can help you out with any of the parts. - Travis |
Agreed, the ride quality in my '69 on bags vs the 40 year old springs was amazing. I have a pic of my '69 at ride height with a ton of hay in the bed. Just add PSI.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
#7 | |||
#8 | |
#9 | |
PM Sent with some extended information and pricing. |
A few things you should think about first is budget and how low you want to go.You can get pretty low with out cutting the bed but if you want to lay frame then cutting and budget come in to play a lot.
Happy to be here
![]() Join Date: Mar 2000
FYI- This is how low you can go running stock fender liners and without cutting the bed.
