Old 05-13-2013, 07:28 PM   #1
1972Banana
u joints for my 72
I went to advance auto to get replacement u joints for my 72 chevy. The guy just did the cross reference on the computer and gave me the joints that came up. Got the old ones out and the first one is too big by 1/8". I know there are two different shafts because the first carrier bearing was wrong and I told him to try again and got the correct one. How do i know what the numbers are for the u joints? The old joints do not have a part number on them. Just gonna get them from rockauto.com but I need the right ones. Any suggestions?
1972Banana is offline   Reply With Quote
Old 05-13-2013, 10:28 PM   #2
Wrenchbender Ret
Re: u joints for my 72
That is such a common part you should be able to walk in any parts store & walk out with it. Take the old one with you & match it up. A good parts man can get it by demensions.
Wrenchbender Ret is offline   Reply With Quote
Old 05-13-2013, 11:36 PM   #3
Shyguy
Junior Member
Shyguy's Avatar
When I worked at O'Rielly's we use to do it quite a bit, they have books to use.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 05-14-2013, 11:19 AM   #4
brad_man_72
the boat guy
brad_man_72's Avatar
Measure the joints. Should be 1310 series. Spicer part number 5-1310x.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 05-14-2013, 01:57 PM   #5
brad_man_72
the boat guy
Or ya know since your shaft needs so much work and needs to be ballanced by a professional anyways just take it to a driveline shop and have them put the right ujoints in correctly, have them check the condition of the rest of the shaft and ballance it, since it needs to be taken to a pro who will have the correct parts laying around for ballancing.
Old 05-14-2013, 02:16 PM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
If he just needs three u joints, its a bit overkill to take it to a driveline shop. Why turn a 40 dollar job into a 200 dollar job ?
Tx Firefighter is offline   Reply With Quote
Old 05-15-2013, 12:13 AM   #7
brad_man_72
the boat guy
He has already replaced the carrier bearing. That alone warrants a ballance job. The ballance always changes when swapping carrier bearings, and the better the ballance the longer the rubber surround will last. if the parts weren't marked and not reassembled the exact way it was when the shaft was ballanced last (probably 40 years ago). The stub for the bolt on yoke for these shafts is usually too long for the bolt to tighten the yoke properly.
If he can't identify the joints that are in the shaft now as original, one can only assume they have been replaced, did whoever replaced them last time mark everything or have the shaft ballanced then?
we charge less than $10 to install our joints, $15 you bring in junk joints from a parts store. If we have to fix the joints you installed improperly at least another $10 if you didn't ruin a $30 weld yoke.
I think a 2 piece ballance is $65 so less than $100 for 3 joints and a ballance. If it ends up being a $200 job the shop had to fix a bunch of stuff you didn't even know was wrong. Probably saving you time, money, and a headache trying to figure out why your rebuilt driveshaft still vibrates.
Old 05-15-2013, 05:41 AM   #8
TBONE1964
Cluster King
TBONE1964's Avatar
The following are the correct u joint part numbers for spicer u joints available for the drive shaft in your truck.
5 - 153X if it has 1.063" cups and outside snap rings (more common for 350 turbo trans in 1/2 ton)
5 - 178X if it has 1.188" cups and outside snap rings ( more common with 400 turbo trans in 1/2 ton)
5 - 3147X if it has inside snap rings. (more common in 3/4 ton)
TBONE1964 is offline   Reply With Quote
Old 05-15-2013, 06:38 AM   #9
Mint68
Mint68's Avatar
That's a good point brad man 72, I never thought about that, but my truck could probably use a balance job too.
Mint68 is offline   Reply With Quote
Old 05-15-2013, 08:35 AM   #10
68_Step
Brad_Man_72: I see you are in Springfield, I am just up the road in Marshfield. Did I read your post right, that you work at a driveline shop? Which one? I know I will need new u-joints soon...
68_Step is offline   Reply With Quote
Old 05-15-2013, 09:14 AM   #11
brad_man_72
the boat guy
Spicer changed all of their part numbers within the last year when they updated those joints.
5-1310x
5-1350x
I can't recall what the part number is for the 3r joint but I haven't seen a 67-72 with 3r joints yet.
