Old 05-16-2013, 10:12 AM   #1
tex_waco_usmc
Project Heaven in my 67!!!
What is the technical name for this???
Need to replace the piece circled in red because the vacuum port that is circled in yellow is broken off and stuck in the end of the vacuum hose. What is the technical name for this part?
Name:  Vacuum problem.jpg
tex_waco_usmc is offline   Reply With Quote
Old 05-16-2013, 10:20 AM   #2
wraprail
wraprail's Avatar
Re: What is the technical name for this???
Cruise control that isn't hooked up so plug it off. That is what I call it.
Now that I see your other post I assume you may be hookig it up so I would say its a cruise control diaphram
Or cruise control motor.
wraprail is offline   Reply With Quote
Old 05-16-2013, 10:24 AM   #3
SCOTI
SCOTI's Avatar
Originally Posted by tex_waco_usmc View Post
Need to replace the piece circled in red because the vacuum port that is circled in yellow is broken off and stuck in the end of the vacuum hose. What is the technical name for this part?Attachment 1107981
Cruise control servo unit. Oreillys has them if you do use your CC.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-16-2013, 10:32 AM   #4
tex_waco_usmc
Thank You! I thought it had to do with cruise control. I looked into the new servo it is $75. But not needed for now so going to plug the line for now and get the motor running will replace in the near future for operation!
Old 05-16-2013, 12:22 PM   #5
Tucson38
Could have sworn it was a ferndock unit. Or maybe part of the flux capacitor for hyperdrive.
Tucson38 is offline   Reply With Quote
Old 05-16-2013, 12:42 PM   #6
meatwagon83
meatwagon83's Avatar
thats the kuneuter valve, it goes to the turn signal fluid reservior!
"DON'T TOUCH THE TRIM!!"-Early Kyler
meatwagon83 is offline   Reply With Quote
