Old 05-17-2013, 02:19 AM   #1351
rhd_c10
rhd_c10's Avatar
Re: Slosh Tubz new company project "Square Peg" frame laying 1987 GMC Jimmy
nnnnnn vvvvvvvvv.................
my rhd build.. http://67-72chevytrucks.com/vboard/s...d.php?t=468712
1964 CHEVROLET BISCAYNE 350CI/TH-350
1968 CHEVROLET C-10 SWB LS1/4L60E
rhd_c10 is offline   Reply With Quote
Old 05-17-2013, 11:08 AM   #1352
jkeating1
jkeating1's Avatar
I think I am building a car vicariously through you! I keep seeing these cool things I want in "my" hot rod. How 'bout an 8.9 liter V12 LS engine!:
http://www.corvetteforum.com/.../man...-ls-engine.php
You wouldn't have to shorten the 6 cyl valve covers---I think that justifies it, huh?
JK
jkeating1 is offline   Reply With Quote
Old 05-17-2013, 11:11 AM   #1353
67cheby
67cheby
67cheby's Avatar
LOL, thanks guys !
67cheby is offline   Reply With Quote
Old 05-17-2013, 11:37 AM   #1354
watahyahknow
watahyahknow's Avatar
http://www.corvetteforum.com/article...-ls-engine.php
the link didnt work this one does i have to say the man has mad welding skills , jesse james must be seeing green (braw lbrawl im the best there is brawl brawl)
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 05-17-2013, 12:54 PM   #1355
jkeating1
jkeating1's Avatar
http://view.internetbrandsauto.com/?...640d7c7217&r=0
Try this one. I didn't notice that it was truncated before!
JK
Old 05-17-2013, 05:11 PM   #1356
watahyahknow
theres a as cast V12 that uses mainly smallblock components for everything but the block and headcastings the crank and camshaft , falconer makes it , this LS1 V12 could be a nice new project for them
http://www.falconerengines.com/falco...2.php?v12=main
startingprice 65000 ........hmmmm now where did i hide that moneytree
Old 05-17-2013, 05:15 PM   #1357
67cheby
67cheby
67cheby's Avatar
Wow
Old 05-18-2013, 03:12 AM   #1358
rhd_c10
rhd_c10's Avatar
thats insane...i want to know the firing order on that... its gonna be fun getting everything to work together it being efi and one of a kind..
Old 05-18-2013, 05:43 AM   #1359
watahyahknow
whell jaguar makes a v12 for years so they couldve used a (lucas) distributor from that
nowadays with all the electronics it isnt to hard to add a few more cylinders
bmw uses two 6 cylinder distributers one per bank of cilinders i think they do the same with the injection
i'm kindah wondering about the ignitionsequence of the 8 cylinder made 12 too , the story does say they weld up two cranks for it adding 4 to the 8 would make it run out of wack i believe ......... then again they could use V6 cranks and have two cylinders fire at the same time or 360 degree apart , doing it that way you could use a v6 ignition with double sparkplugs (cilinder 1 firing the workstroke while two is firing during the exauststroke)
been looking into sumtin like this myself (lets just say benchracing doesnt cost a lot exept time )
http://www.jalopyjournal.com/forum/s...d.php?t=533613
i wanted the engines to sit inside the bed but running them the normal way around would make the setup to long to hook up to the rearaxle
my idea was to run a setup like that reversed in the bed of a pickup close to the cab with the transmission sticking into the cab driving a v drive or transferbox in front of the cab then a driveline going back between the engines to the rearaxle or both wishever my thought where at at the time , the radiators would find a place at there original spot behind the grille the fueltank would prolly be behind that or at the rear of the bed
i think it might make a good showmachine for mudbogging as most of the weight would be pretty centered the engines dont need to be special or realy powerfull as there both working , the expencive part would be the connection between the two engines and the trans , was thinking using gear camdrives sandwished between engineplates filled with engineoil like setup for that
Old 05-18-2013, 08:43 AM   #1360
68Timber
I know the pieces fit
68Timber's Avatar
Lets try not to get too far off track, there's a pretty cool build going on in here somewhere.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 05-18-2013, 08:58 AM   #1361
BigDaddyV
BigDaddyV's Avatar
Thats what I was thinking. I wanna see the slammed draggin arz Blazer.
J. Vess, 6'6", Gearhead, Welder, Fabricator, Nutcase
1955 Chevy Stepside "Dudley"
My daily http://www.67-72chevytrucks.com/vboa...d.php?t=760288
1972 Chevy C10, Project "Chevro~Layed out" Nether Storm
Build Thread http://67-72chevytrucks.com/vboard/s...23#post6007523
BigDaddyV is offline   Reply With Quote
Old 05-20-2013, 11:31 AM   #1362
67cheby
67cheby
67cheby's Avatar
LOL....well here is some great weekend progress, lifted the mounts
Old 05-20-2013, 11:34 AM   #1363
67cheby
67cheby
67cheby's Avatar
next widened 1 1/2 inches and lifted 6 inches. It will have a false floor raised 6 inches to match the raise of the Tubs and then hinged for storage
Old 05-20-2013, 11:34 AM   #1364
77ChevySharkBite
77ChevySharkBite's Avatar
Looking good and sharp Mike!!!!!!!!!!!!
I'm getting ancy to see this beauty!!! AHHH!!!!!
Korwin
77 C10 Silverado Sharkbite LWB Build
67 Chevy C10 Frame Off
06 Dodge Magnum 2.7v6 aka swag wag!
2010 Honda Accord 2.4I4 DD aka Liquid Metal
77ChevySharkBite is offline   Reply With Quote
Old 05-20-2013, 12:26 PM   #1365
BigDaddyV
BigDaddyV's Avatar
Love it!
Old 05-20-2013, 03:34 PM   #1366
Bennett68C10
Bennett68C10's Avatar
Nice job on the tubs
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 05-20-2013, 03:51 PM   #1367
oldman3
oldman3's Avatar
By the looks of it, you would think someone was going to put large wheels and tires on it...Jim
oldman3 is offline   Reply With Quote
Old 05-20-2013, 04:01 PM   #1368
67cheby
67cheby
67cheby's Avatar
Thanks guys ! We got a little love from Royal Purple today only the best for Square Peg !
Old 05-21-2013, 12:46 AM   #1369
Rusbuilt
Rusbuilt's Avatar
Looking good Mike!
Rusbuilt is offline   Reply With Quote
Old 05-22-2013, 09:09 AM   #1370
67cheby
67cheby
67cheby's Avatar
well I ran out of welding wire last night so I decided to start my Step by Step Slosh Tubz install so here goes !
Old 05-22-2013, 09:14 AM   #1371
67cheby
67cheby
67cheby's Avatar
Step 1. Tape 2 pieces of poster board together
2. Lay the tubz down centered on the board
3. Trace the bottom shape onto the poster board
4. Cut out the bottom shape
5. I used the garage door, this works better if you have someone to hold it for you ! LOL, Place the cut out section on the back of the Tubz and trace out the arch of the Tubz
Old 05-22-2013, 09:20 AM   #1372
67cheby
67cheby
67cheby's Avatar
6. Cut out the arched piece, this is what you will use for your pattern, save the other pieces they are the patterns you need to make trim panels to go around the Tubz
7. Now tape the pattern onto the inner fender with the bottom contour following the bottom contour on the fender (this will make more sense when you are looking at it all apart)
8. Trace the top of the pattern onto the fender
9. The bottom edge needs a line marked following the edge of the squares where the nut clips go in, once again this will make sense when you are looking at it
10. Now use what ever cutting tool you prefer and cut it out , I like a 4 inch angle grinder with a cutting blade
Old 05-22-2013, 09:24 AM   #1373
67cheby
67cheby
67cheby's Avatar
11. Next you are ready to bolt in your Slosh Tubz !!
Note these Square body Slosh Tubz were designed around the 80-87 front clips, so there are going to be some modifications to make them work on the 73-79 clips, nothing major, just some of the bolt holes are in different locations so as soon as I get those done I will post those pics also !
Old 05-22-2013, 09:30 AM   #1374
jlsanborn
jlsanborn's Avatar
Sweet Tubz!!
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 05-22-2013, 09:43 AM   #1375
watahyahknow
looks good , i think the biggest problems with making tubs youreself from trailerfenders is making it fit the shape of the inside of the outer fender to prevent roaddebrees and stuff from collecting between the two parts
it might be an idea to run some channel rubber over the cut piece before installing the sloshtub
nice thing about that is that you could hide quite a gap with it and prevent some of the wet gunk comming intoo the space between the inner and outer fender to drip down the visible side inside the engine compartment
