Old 05-16-2013, 09:49 PM   #1
jmking9
jmking9's Avatar
Throttle Linkage
I need to build a new linkage to my carb on my 70 with a 350 and an edelbrock carb. What have you guys used for this? I cant seem to find anything. Im looking for something like this that I found in a pic that 68Stepbed had on his truck. Can anyone point me in the right direction.
1970 SWB Build
jmking9 is offline   Reply With Quote
Old 05-16-2013, 10:08 PM   #2
Lattimer
Lattimer's Avatar
Re: Throttle Linkage
I used a piece of 1/4" threaded rod and 2 heim joints off Ebay. Less than $20 and works great, looks pretty much like your photo.
You can see the one end on page 4 of my build thread.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 05-16-2013, 10:58 PM   #3
WIDESIDE72
WIDESIDE72's Avatar
I read somewhere on here where guys would use the shift rod off a Harley that most of the Hog guys discard for one with more "bling".
WIDESIDE72 is offline   Reply With Quote
Old 05-16-2013, 11:01 PM   #4
WIDESIDE72
WIDESIDE72's Avatar
Can anyone tell me what the distance is from the linkage on a Qjet carb to the pedal rod at the rear (ie how long does the rod that connects the two need to be)?
Old 05-17-2013, 09:19 AM   #5
TobyArnot
Quit if it's not FUN!!!
TobyArnot's Avatar
That's basically what I did. Bent a slight offset in the rod to make it line up with the Q-jet. Once I got the length right, I slipped a piece of rubber hose over the threade rod to "clean" it up some.
TobyArnot is offline   Reply With Quote
Old 05-17-2013, 11:15 AM   #6
hayhauler71
hayhauler71's Avatar
I used a 3/16 thick piece of aluminum and parts from one of the cheep $10.00 throttle bracket kits
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 05-17-2013, 11:52 AM   #7
BugzC10
BugzC10's Avatar
I just installed this linkage from Jegs. Fits and works great.
JEGS Performance Products 15795 Adjustable Throttle Linkage Rod
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline   Reply With Quote
Old 05-17-2013, 01:08 PM   #8
leftybass209
leftybass209's Avatar
I agree with heim joints and all thread. Just purchase more length than you need and cut it down. Someone else's measurements are to their preference with their particular joints. Pedal feel, bends, and things in the way at WOT will influence your specific rod length. Good luck.
leftybass209 is offline   Reply With Quote
Old 05-17-2013, 07:30 PM   #9
jmking9
jmking9's Avatar
Just ordered that exact setup. Did you have to modify anything at the pedal end since that hole isnt 1/2"?
Thanks everyone for your help. This is the only thing keeping me from driving my truck, so Im a little eager to get this taken care of.
1970 SWB Build
Old 05-17-2013, 07:56 PM   #10
BugzC10
BugzC10's Avatar
Didn't have to modify anything. There are step washers that fit the 1/2" hole on the carborator linkage. The bolt is actually 1/4-20. I thought I would have to drill out the pedal rod, but it fit perfectly. Pedal feels great.
Old 05-17-2013, 09:26 PM   #11
c10srule
c10srule's Avatar
we used a floor shifter linkage rod on dads
c10srule is offline   Reply With Quote
