Old 05-19-2013, 02:02 AM   #1
Spartan
Spartan's Avatar
Manual trans question
The power team chart says I have a ch465 4 speed.
I thought I read somewhere it was a M20.
Is there a simple id I can look for?
I went to the heritage site and indication there is same power team chart.
Any suggestions, comments?
Many thanks.
Cheers,
Nim
'69 K20 350/4 speed/Rockwell/D44/HO52.
"orange rhymes with door hinge"
Spartan is offline   Reply With Quote
Old 05-19-2013, 02:15 AM   #2
razo88
Re: Manual trans question
Pretty sure have an sm465....pics would be nice..
razo88 is offline   Reply With Quote
Old 05-19-2013, 03:15 AM   #3
SS Tim
SS Tim's Avatar
The CH465 is an internally shifted wide ratio four speed transmission with a low first gear.
It is listed as RPO M20 on the SPID.
It is not the same as the externally shifted car transmission by the same name.
In the factory service manual it is the Muncie Four Speed trans.
SS Tim is offline   Reply With Quote
Old 05-19-2013, 01:46 PM   #4
Spartan
Spartan's Avatar
Thanks folks!
The m20 was on my spid. I figured it out after scratching my head for a half hour.
Tim- many thanks. As always
Cheers
Nim
Old 05-19-2013, 04:22 PM   #5
Mike C
Mike C's Avatar
M20 is just the option number for a particular platform, in your case, C/K series trucks. M shows transmission and 20 is GM's code for wide ratio 4 speed. In a performance car, it would have been the 2.52 first gear Muncie aluminum case side shifted trans. In a base model car it would have been a Saginaw side shifted iron 4 speed. And in a truck, it is the iron case top shifted SM465 which is also referred to as the CH465 in some literature, mostly early stuff.
Synchro-Mesh is what consensus seems to be that SM stands for, but who knows? It is also known as the 117mm 4 speed FWIW.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
