Old 05-18-2013, 07:05 PM   #1
Mattman2010
Mattman2010's Avatar
6.2 Diesel problems
I have a 1980 chevy k10 that I swapped a 84 Military blazer 6.2 into and it has been running fine for the past year. But last week it quit running. I put more fuel in it (gauge is tricky at times) and I am getting a good flow of fuel out of the filter mounted to the firewall. I noticed lately even on warmer days that the engine needed 10 seconds of glow plugs, crank, and 10 more seconds of glow plugs and it would fire right up. I have also noticed that when you let off the throttle it does not "fuel down" as fast. Before when you let off the throttle you could feel the truck slow down pretty fast. I have fuel and I have 12volts to the injection pump. When the truck quit running it was running really sluggish and then just died and would not fire back up. Is the injection pump bad?
Thanks, Matt
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 05-18-2013, 10:42 PM   #2
Mattman2010
Re: 6.2 Diesel problems
Got it running, must have gotten a ton of air in the system with a really low tank. Guess I need to check my fuel gauge now.
Build Thread
Build Thread
Thread
Old 05-19-2013, 05:49 PM   #3
Daveyboy1983
Ya good rule of thumb always put fuel in to start lol glad that's all that was wrong
Daveyboy1983 is offline   Reply With Quote
Old 05-19-2013, 06:50 PM   #4
68Timber
I know the pieces fit
68Timber's Avatar
Good to hear it. Have you thought of swapping to the spin-on fuel filter? I haven't modified my 6.2 at all yet but that looks like a good upgrade. I don't recall what it was but seems like it had some benefit over stock for getting air out of the lines.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 05-19-2013, 07:19 PM   #5
Mattman2010
Is it weird that it kinda made me mad to know this motor was still going to run?
I have not done anything to the 6.2. I have a 6.5 turbo setup I need to put on it, because this 6.2 really makes me miss my 350 but my 350 needed rebuilt and this motor seems to run, but to sluggish for me.
Build Thread
Build Thread
Thread
Old 05-19-2013, 07:29 PM   #6
68Timber
68Timber's Avatar
10 4. I've got all the 6.5 turbo parts too, for later on down the road. Glad you got it running again.
John
74 Honda Z50 build
Old 05-19-2013, 07:49 PM   #7
Mattman2010
Yeah ill probably be putting my kit on when I finally get the crew cab cummins on he road. I have basically figured out everything I need to do the swap, so when I get down to it it should be easy.
Build Thread
Build Thread
Thread
