02-07-2013, 02:44 PM | #1 |
65 C20 not starting
Hey guys, new to the forum been lurking around for a few weeks getting some ideas for my C20 build. Im getting ready to start the build soon and went to try to start it a few weeks ago but couldnt get it to fire. Got some starting fluid and it fired right up only to die a few seconds later. After a little fiddling with it i removed the fuel line going right into the carb and had no fuel coming out. Any ideas on what this could be? or maybe even a temp cheap fix, just need to be able to move it a tiny bit nothing far or a long ways. Thanks in advance for your time.
BTW- inline 6 motor. Also just noticed i was in the wrong section when posting. Mods please move to appropriate section, please/thank you. Last edited by swagger_jacker; 02-07-2013 at 02:45 PM. Reason: Wrong section |
05-03-2013, 11:22 AM | #2 |
Re: 65 C20 not starting
Welcome aboard.
Whats your plans and any pics? You'll like it here. |
05-04-2013, 04:41 PM | #3 |
Disconnect line at pump inlet and determine if tank/line/filter is plugged.
Fuel pump diaphragms rot over time; so test pump as well. |
05-16-2013, 12:51 PM | #4 |
I agree, check condition of inside tank & lines and a new fuel pump...bout $30, should do the trick. Probably wouldn't hurt to replace the rubber fuel lines and filters also.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
05-16-2013, 08:35 PM | #5 |
disconect line going to fuel pump, use gas can and try it. this will tell you if your tank,fuel line are clogged. if that does'nt work it could be youre fuel pump
05-19-2013, 07:44 PM | #6 |
Hey guys sorry for the very late reply, was able to get the truck running. Pulled the carb apart and found the bowl dry and a float was stuck closed not allowing fuel in; however of course after i get it running and about to start fixing it up my job comes down and tells me I have to move to Miami from Seattle. so I now have to put the truck up for sale. so if anyone is interest it is available. I just need to figure out how to post it to the classified section. Maybe once i get to Miami I can find another one to work on.
