Old 05-15-2013, 03:30 PM   #1
FL71C10
How hard is it to replace vent window glass?
I have a pair of nice chrome vent windows but I want to put tinted glass in them. How hard is that to swap out? Are they just glued in there?
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 05-15-2013, 08:51 PM   #2
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: How hard is it to replace vent window glass?
When I rebuilt the vent windows in my K10 I took them and OEM tinted glass to a local glass shop and had them do the glass install. The glass is held in place in the frame by a C-shaped strip of rubber. It wasn't pricey.
Old 05-16-2013, 12:34 AM   #3
JOJABOY
Really easy if you are just replacing glass. Use a small flat tip screw driver and work the top and bottom and then move to the corner. It will slide out. You can get a roll of window cork tape stuff for about $3.
I have seen some people reuse their old rubber gaskets. I bought the cork tape stuff...found it to be difficult to work with and ended up picking up some thin rubber matting, cutting it with some scrap book cutter think then heating it with a heat gun and just slid the glass right in.
If you are ever going to replace the entire vent window assembly....you will need a large tube of patience! LOL
JOJABOY is offline   Reply With Quote
Old 05-16-2013, 06:54 AM   #4
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
I removed some glass from the frames but still haven't installed any yet.
I used a heat gun on the frame and I think it helped. Use a blunt type tool and gently work the glass out.
You'll know if you made a mistake or handled it too rough as your window will now be in very small square peices everywhere.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 05-20-2013, 10:11 AM   #5
FL71C10
Thank you both for your help. I think I have an old one I will try it out on first.
