Old 05-19-2013, 08:29 PM   #1
Claytona08
Claytona08's Avatar
Foose Legend Wheels
I am looking into ordering some Foose Legend wheels in the near future for my 84 C10. I am going to buy 20x8.5 for the front and 20x10 for the rear. I plan on running some Toyo Proxes 255-40-20 in front and 295-40-20 rear. Also I am going to order a 5"-5" DJM drop kit with drop shocks. The main questions I am having are will I run into any problems with the lowering kit and rim/tire setup. Also what backspacing should I use for the front and rear?
http://www.pitstopwheels.com/images/...d%20Chrome.jpg
Claytona08 is offline   Reply With Quote
Old 05-20-2013, 01:36 PM   #2
Claytona08
Claytona08's Avatar
Re: Foose Legend Wheels
Anyone know the backspacing needed?
Old 05-20-2013, 02:12 PM   #3
Cherub
Cherub's Avatar
to be sure you will need to know the offset. On 10" wheels 5.5 and 8.5" wheels 4.5 are common backspacings for our trucks. With a tape, plumbob or straight edge you can figure out what will work for your setup.
Cherub is offline   Reply With Quote
Old 05-20-2013, 02:13 PM   #4
JWall
Frequent Flyer
JWall's Avatar
Here's my wheel tire specs with about 6/8 drop...
Boss 338's - 20x8.5 with 255/35/20 & 5.25 backspacing up front
20x10 with 275/35/20 & 5.5 backspacing in the back
- Justin
1 Owner 1976 SWB
Old 05-20-2013, 02:46 PM   #5
Claytona08
Claytona08's Avatar
Thanks,
Nice truck you have!
Old 05-20-2013, 03:01 PM   #6
Claytona08
Claytona08's Avatar
Alright thanks for the info. I want the front to have a small lip exposed whereas on the rear I would like a much larger lip exposed.
Old 05-21-2013, 03:49 AM   #7
andrewmp6
Or get you a percy's wheelrite it will let you test fit any size wheel and tire you can dream up.
Old 05-21-2013, 08:06 AM   #8
Claytona08
Claytona08's Avatar
Thanks, I will have to look into this.
