How much would a double wall top be vs a single wall top?
I was curious, if one is more valuable then the other? |
![]() Join Date: May 2007
Re: How much would a double wall top be vs a single wall top?
Single wall is much more desireable. Seems like you can't give away a double wall. From what I have seen, double walls like to sag and come apart, down the center interior seam. Single walls don't require the interior panels to be removed, to take off the top, and single walls have dome lights.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
I agree with Turp. I had two double walls once and I tried to give them away but couldn't. I finally took them to the landfill.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
![]() Join Date: Apr 2006
Yeah the single wall is much more desirable. I hate to see people take double walls to the landfill because no one will take them. You would think someone could use a top since there is no replacement. I personally have a 72 with the single wall. I had a 71 in the past and wanted the single wall so I bought one. I believe I paid 700 and it came with the hatch but that was 7 or 8 years ago. Took me months to find one. I wouldn't even consider selling my single wall now but that's me. I think I would expect someone to ask above 1k if its in good condition. If you have a single wall I would say keep it they will go up in value or you could use it if you ever need it for a non single wall Blazer. They are hard to find and people mostly over price them if they know what they are. They only made them the later half of 72.
Kirk 72 Blazer CST 4wd highlander 66 Nova |
I have double wall on my blazer now. Long story short, time constraints led to buying a second double wall just for hatch, as it would take to long to fix the hatch that is on the truck now(it is cracked right at the top left hinge. )
So I have the extra double wall with a crack in the hinge. I think I will keep it. I have second truck, that also had a double wall on it, that I was going to use for parts, even though, according to previous owner, it ran great before he started stripping it down for resto. It has almost everything, just scattered in the bed of blazer, still attached, or in the barn. Reason for the post, I was weighing, should I sell this new top or keep? If I had my choice I would keep everything and eventually restore this truck as well. Also I know this truck came with factory doublewall, and I think my other(the one currently getting restored) was a single wall and they had to do some rigging or drilling to get the double wall to work on it, 2 yrs ago for another film it was in. |
I see double walls once in a while in Cali craigs listings anywhere from $500-1000 and they're usually gone in days. Sounds like I should be going and digging them up out of those South Dakota landfills
I find this thread to be a bit shocking. When we were shopping for our Blazer, my wife and I were pretty insistent about getting a rig with a double wall top. Seemed to be a no brainer in that it would keep the truck cooler in the summer and warmer in the winter.
The doubles are lower in quality than the singles? Is that the main reason you all like the singles better? |
I think the main advantage to single wall is the ease of removal.
Didn't 72's only come with single walls? That would be another reason they are in demand more since there were alot more Blazers built in 72 then previous years.
I have been looking for a single wall for about 5 years. Was considering about a 500 mile radius, now I have expanded that. So if anyone knows of any in the MN ND or SD let me know.
1969 Chevy Custom Camper 3/4 ton Rust free survivor 1972 Chevy Blazer CST 4x4 Almost Rust free survivor 1972 GMC Jimmy 2wd Undergoing surgery |
72's could have either.
My 72 has the original double wall.
At least I think it does. |
Mine has a double aswell but I did just buy one that's a 72 that has a single wall so it's a crap shoot I guess
Posted via Mobile Device |
Easy way to tell if its single or double wall is the rear bolts that hold it down. If they go down from the top it's a single and if they come up from the bottom it's a double wall.
#14 | |
I wish I could find one of these double walls people are giving away, as every time I go to look for one, people want $400-$750 for a top, not necessarily with the hatch. And, it's still a few hundred miles away.
1954 Ford F-100 1956 Chevy big window 1970 4x4 Blazer CST 1987 Land Cruiser 1990 Chevy K3500 454 |
#15 |
I thought the main advantage to the single wall was it was less likely to become wavy on the top, like most if not all double walls do. I think there is some weight difference, but it wouldn't be enough to keep me from using one.
#16 |
I have looked and looked for single walls. Double walls are always for sale for $150 + - in Seattle area but honestly they should be free for the taking. I am sure the reason a guy is selling them is because they are 1) heavier, 2) sag, 3) more difficult to remove 4) don't have dome lights. That said, the glass is worth more than the top.
#17 |
I passed up on buying 2 '72 Blazers a year ago. Was in a financial bind but knowing what I do now it would have been a great investment. Both were '72. Both pretty rough. One was a driver with the usual rust and the other was more of a parts rig. Now the sad part....they only wanted $2500 for the pair.
The thought of selling my single wall has crossed my mind several times. I never use it except to keep the snow out in the winter. Haven't had it bolted down since buying the truck 3 years ago, but seeing how hard to find they are I think I better hang onto it. Who knows, maybe someday I'll put heat back in and want to drive it in the winter. Sorry 69-72. Your search was what got me thinking about selling, but for now anyway, your search continues. I still have my eyes open for one for you though. |
#18 | |
