Re: Lunati Voodoo
Here's basically the same cam from Jegs. You'll have to buy lifters though. Ther made in USA. I just put the same cam in my 283 only the next step down. I haven't had it in very long but I like it so far.
http://www.jegs.com/i/JEGS-Performan...d=#moreDetails
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member). |
Senior Moment
![]() Join Date: Mar 2002
Re: Lunati Voodoo
I've had the Lunati Voodoo in my Big Block and it was better than any Comp Cam I've ever Run. I now have Lunati's version of the BB cam that came in the 1969 Chevelle SS (Solid Lifter) and absolutely Love it
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
Re: Lunati Voodoo
The voodoo line of camshafts were designed by Harold Brookshire formerly of Ultradyne camshafts, he is a genius when it comes to cam profiles and I believe there is nothing off the self that can touch his profiles.
Posted via Mobile Device |
I built it
Re: Lunati Voodoo
i have the smallest voodoo roller in my big block, in the few trips ive taken with it i LOVE the cam! fantastic power down low.. and ive only even gone about 1/2 throttle yet. havent got it over 3k yet either so i dont know how itll rev..
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness '98 dodge 3500 12v 5sp 4x4. the truck that actually runs |
#6 | |
Re: Lunati Voodoo
'67 2wd LWB 350/4speed. |
Re: Lunati Voodoo
It's been ordered! Would you guys recommend new valve springs with this as well? Or, since it's not a very big cam, will they be adequate.
I built it
Re: Lunati Voodoo
i personally would get new springs.. they are probly quite old and used up, IF they even have clearance before bind.. its one of those "might as well do it right" things
US Army Veteran
![]() Join Date: Nov 2008
Re: Lunati Voodoo
Just to keep the anticipation of what you are in store for, here's a video of a Lunati Voodoo cam in my 383 stroker with Corsa exhaust:
Ran like a scalded ape, would be an understatement.
1972 C10 Highlander - The making of a daily driver |
