Old 05-21-2013, 09:05 PM   #1
Daveyboy1983
Lower ball joint problem!
Ok so got my arms all painted up, new moog ball joints and bushings all pressed in and ready to rock....So I get the lower arm mounted and spring in and am ready to throw the spindle on and I set it on the Lower ball joint and the ball joint falls out of the arm it goes back in with a few light taps of the hammer but is a little loose in the hole...what do I do now??? How do I fix this???
Daveyboy1983 is offline   Reply With Quote
Old 05-21-2013, 09:17 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Lower ball joint problem!
Buy a Moog "problem solver" balljoint.
Keith
Convert to disc brakes.
Old 05-21-2013, 09:21 PM   #3
S10Fan
Old Heap Driver
Yep. I've also seen folks tack weld the ball joint. Check your control arm for cracks around the ball joint hole after you install the "problem solver" joint. I've seen the arm develop cracks if care isn't used installing an over sized joint.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 05-21-2013, 09:32 PM   #4
Daveyboy1983
I have a moog problem solver ball joint
Old 05-22-2013, 07:01 AM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Put a couple of tack welds on the bottom where the ball joint and arm meet. The lower ball joint is under tension so it's not prone to falling out. Many trucks have had to be tack welded in the past.
Tx Firefighter is offline   Reply With Quote
Old 05-22-2013, 07:58 AM   #6
Daveyboy1983
Last night I took a punch and went around the edge of the hole under the arm and shrunk it a little bit and then took a brass drift and pounded the ball joint back in with a sledge hammer it seems to be tighter now so just as a precaution I soaked the splines of the joint in red loctite and then put the jack stand under the ball joint with the trucks weight on it to hold it in place with the spindle and everything mounted...We will see if that holds and as a last resort if I have to I will tack weld the bottom of the ball joint hate to do that but then if I must, I must haha!
Old 05-22-2013, 09:40 AM   #7
wraprail
wraprail's Avatar
X2 Tack weld. Done it many times.
wraprail is offline   Reply With Quote
Old 05-22-2013, 11:46 AM   #8
Billy81
Billy81's Avatar
Must be a common problem because i have seen quite a few of these trucks at the wrecking yard that had at least one of the lower ball joints tack welded to the arm.
Billy81 is offline   Reply With Quote
