Old 05-22-2013, 05:19 PM   #1
jayoldschool
Moderator
What's up with my trailing arms?
After looking at many pics of projects in this section, I realize that there is something strange going on with my truck's trailing arms. Mine have space between the two halves. Didn't realize this was not correct. Also, I thought that the stuff in the space was just rotted wood debris from the decayed bed, but after getting a closer look with the bed off, I can tell it is metal. I have no idea why that would be in between the two halves of the trailing arms.
Not sure what to do here...
Here are the scenarios that I can think of:
- do nothing
- try and knock that strange metal out of there and squeeze the halves back together, then bolt or weld
- start shopping for a pair of arms
Thanks for any thoughts.
Here's the pics:
jayoldschool is offline   Reply With Quote
Old 05-22-2013, 05:43 PM   #2
vegadesign
vegadesign's Avatar
Re: What's up with my trailing arms?
looks like you need to find a new set man!
or start drilling and bolt them back together
"its not a hobby, It's a Lifestyle"
bagged and soon to be bodied 70 longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=564028
vegadesign is offline   Reply With Quote
Old 05-22-2013, 05:51 PM   #3
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Yea, that crap is not supposed to be in there.. It looks like rust build up.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 05-22-2013, 05:52 PM   #4
LT1 Burb
LT1 Burb's Avatar
I have 2 sets if your interested
LT1 Burb is offline   Reply With Quote
Old 05-22-2013, 06:33 PM   #5
jayoldschool
Moderator
Thanks, sent you a PM.
I really don't think that the stuff in between the halves is rusting OE metal. The arms look good from the sides. It's like someone jammed it in there... a long time ago. I'll see if I can knock some of it out.
Old 05-22-2013, 09:09 PM   #6
Greg63
Enjoy your truck
Greg63's Avatar
Mine started doing that too (original Canadian pieces). It was rust that was spreading them apart so I replaced them.
The wood is probably desbris that fell down from the bed floor (or the bed floor itself).
Greg.
1 Corinthians 10:13
1963 Chevrolet 1/2 ton
2010 Camaro SS/RS
2014 Jeep Grand Cherokee
2016 Jeep Cherokee
Greg63 is offline   Reply With Quote
Old 05-22-2013, 09:15 PM   #7
Sharps40
Time to replace those truck arms. The sides should be in contact but them are bout ready to fail and I doubt boltin em up will be a long term fix.
Sharps40 is offline   Reply With Quote
Old 05-22-2013, 10:13 PM   #8
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Folks in rusty areas of the country call that rust jacking. When two tightly joined pieces of steel rust, they wedge apart like that.
Tx Firefighter is offline   Reply With Quote
Old 05-22-2013, 10:36 PM   #9
Brown62
Brown62's Avatar
Mine were the same way. I also thought it was some sort of wood. Just rust and dirt. The u-bolts and spring cup bolts are also in there and they were almost rusted into. Bad design.
Brown62 is offline   Reply With Quote
Old 05-22-2013, 10:41 PM   #10
MARTYZ
MARTYZ's Avatar
Jay , have to agree with everyone above here, Replace them! Only problem is to find a good set around this part of the country.
MARTYZ is offline   Reply With Quote
Old 05-22-2013, 11:20 PM   #11
LT1 Burb
LT1 Burb's Avatar
I have never seen a set of trailing arms look like that, must be all that salt in your diet, luckily its illegal here to salt.
Old 05-22-2013, 11:22 PM   #12
jayoldschool
Moderator
Brought this truck up from Arkansas... found out that it lived in Wisconsin for most of its life
Old 05-23-2013, 08:22 AM   #13
Clyde65
Clyde65's Avatar
I think some bondo would fix it!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-23-2013, 08:48 AM   #14
1963c-10
1963c-10's Avatar
Time to replace them
1964 Short bed trailer
Old 05-23-2013, 11:02 AM   #15
63burban
Chevy addict
Welcome to the things we deal with in the midwest
63burban is offline   Reply With Quote
