Closed Thread
Old 05-26-2013, 04:41 PM   #2301
lowdownstar
big guy
lowdownstar's Avatar
Re: What Did You Do With Your Truck Today ?
Originally Posted by mknittle View Post
Congratulations Ray!
Thank you! this is a pic of my son and his new wife!!!
lowdownstar is offline
Old 05-26-2013, 06:20 PM   #2302
FarmerSid
FarmerSid's Avatar
You must be proud! All the best to them.........
FarmerSid is offline
Old 05-26-2013, 07:44 PM   #2303
lowdownstar
big guy
i am thank you, his is a great kid and she is a sweet heart...
Old 05-26-2013, 07:58 PM   #2304
JWright3632
Got my grille trimmed and fitted onto my front fenders, measured and marked my core support so I can shorten it, put the hood on made sure its all square.....
Measure Twice, Cut Once Saves Lives!!!!
JWright3632 is offline
Old 05-26-2013, 09:21 PM   #2305
NEWFISHER
NEWFISHER's Avatar
Looking good, is that still your mock up cab?
NEWFISHER is offline
Old 05-26-2013, 09:28 PM   #2306
JWright3632
Im gonna try to salvage it, with the body being so low, I gotta cut the floor for a trans tunnel, and with the floor being so rusted Im gonna just cut the floor out from the tow boards back to the rear of the cab and do a custom floor. Im pretty confident I can fix the cab, sure beats spending 400 on a better one when I can fix this one with 150. Im about to move it to my shop so I can work on it more.
Old 05-26-2013, 10:19 PM   #2307
mknittle
mknittle's Avatar
Good looking couple! They are lucky to have your whole hearted approval. You should be proud for sure!
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline
Old 05-26-2013, 10:23 PM   #2308
mknittle
mknittle's Avatar
That sounds like a winner!
Mark
My GMC build.
mknittle is offline
Old 05-27-2013, 03:02 AM   #2309
RedneckRodder
RedneckRodder's Avatar
Spent the day yesterday replacing struts and strut mounts on the little lady's car, that freed me up to spend the rest of the weekend on my truck. RULE #1 If she ain't happy, you ain't happy.
Finished engine and tranny mounts today. The engine is now completely installed, hopefully for the last time! Tomorrow I plan to fill the hole in my floor that was cut out to compensate for the bell housing's new location.
RedneckRodder is offline
Old 05-27-2013, 03:12 AM   #2310
Daze57
Daze57's Avatar
worked on running wires from door; thru cab via new wire looms - running wires for the power windows and solinoids for shaved door handles bit of a p i a but not too bad ,
all ran and all done
On this memorial day we remember our brothers and sisters that gave there lives past and present .................Thank you !- you are not forgotten !!!!!!!
Daze57 is offline
Old 05-27-2013, 07:40 AM   #2311
dubie
dubie's Avatar
I installed a new set of front park lamp assemblies, and all new firewall grommets last night. Tonight I'll be finishing up some touch up painting in the cab so the new headliner can be installed. I took 2 weeks off from working on the truck to get some things done around the yard and do some repairs to my faithful daily driver so now it's time to giver on the truck again
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline
Old 05-27-2013, 03:19 PM   #2312
Dan in Pasadena
Dan in Pasadena's Avatar
Wow, beautiful young couple. If she's half as beautiful a person on the inside as she is on the outside, they'll be very happy. Best Wishes, Dan.
Dan in Pasadena is offline
Old 05-27-2013, 03:25 PM   #2313
broey
Square
broey's Avatar
well, yesterday my truck went from this:
to this:
thanks to help from about 40-50 board members!!
Squarebody Syndicate
broey is offline
Old 05-27-2013, 05:15 PM   #2314
Dan in Pasadena
(Wolf whistle!) Wow, she looks great. Really? In one day?
Old 05-27-2013, 05:48 PM   #2315
broey
Square
broey's Avatar
yup, started at 10 and finished at 6. full porterbuilt front and rear kit.
broey is offline
Old 05-27-2013, 07:52 PM   #2316
lowdownstar
big guy
Thanks Dan
Old 05-27-2013, 10:03 PM   #2317
mknittle
mknittle's Avatar
Mine sat out under a tarp in the rain today! while schemed and planed a little on my next project. The 72 4x4 I can't help it I am addicted!
Mark
My GMC build.
mknittle is offline
Old 05-27-2013, 10:56 PM   #2318
NEWFISHER
NEWFISHER's Avatar
My kind of motivation! I like the way you work
Old 05-27-2013, 11:22 PM   #2319
mechanixman
mechanixman's Avatar
to this:
Somethings wrong.....looks like your springs collapsed!
I'm just messin, it really does look great
-Nick
Projects:
1952 Chevy 1 ton = The Build page
mechanixman is offline
Old 05-27-2013, 11:23 PM   #2320
mechanixman
Brake work, and I finally mocked up my 327
-Nick
Projects:
Old 05-27-2013, 11:23 PM   #2321
FatFenderGarage
FatFenderGarage's Avatar
Milled up some black walnut for a new wood bed. Plans are to finish tomorrow and install Wednesday.
FatFenderGarage is offline
Old 05-28-2013, 01:10 PM   #2322
dubie
dubie's Avatar
new park lamp assemblies and I finished the interior painting by spraying the doors white
dubie is offline
Old 05-28-2013, 03:16 PM   #2323
Russell Ashley
Russell Ashley's Avatar
I got my new floor mat and sound insulation installed. The PO "clearanced" the firewall to make room for an HEI distributor and I think that's the reason for the wrinkle in the mat. I might have to cut it at the trim line and let it overlap slightly if it doesn't lay down after being in the sun for a while. Notice how well the pre-cut hole fits the dimmer switch. Also got my Lokar thru-floor accelerator installed with my original style pedal. I drilled and tapped two holes in the Lokar pedal and used two black flat head allen screws to attach the old pedal. I'm in the process of swapping carburetors so can't finish the cable yet. My old Quadrajet didn't have a choke so I picked up one off of CL with an electric choke and rebuilt it. My EZWire harness has a connection for the electric choke but I didn't need it when I wired the truck so I bundled it in the harness. I want to fish it out and route it while the carb is out of the way.
If you are ever going to install a Lokar pedal like this one do it before you install the engine. It's a PITA with the engine in place.
Russell Ashley is offline
Old 05-28-2013, 03:19 PM   #2324
NEWFISHER
NEWFISHER's Avatar
I agree with the LOKAR pedal install, waaaaay easier with the engine out! Even having the trans out would have made a huge difference.
Old 05-28-2013, 04:38 PM   #2325
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Nice mod of the pedal Russell! May I copy that one!
ChuckDriver is offline
Closed Thread
