Old 05-28-2013, 03:13 PM   #1
94cummins12v
94cummins12v's Avatar
1959 gmc 450
Hey guys new to the forum but not to trucks about a month ago I picked up a 1959 GMC 450 truck with a 16' dump bed in it if anyone has any spec sheets or information about these trucks that would be greatly appreciated and also the owners father did a complete engine overhaul a couple years back but he passed and the owner didn't know what size engine it is I'm thinking a 292 inline 6 is what's in it but if anyone knowledgeable about these could chime in that would be great
94cummins12v is offline   Reply With Quote
Old 05-28-2013, 03:45 PM   #2
buggy5872
buggy5872's Avatar
Re: 1959 gmc 450
Got any pictures?.....We like pictures here. The engine if original would most likely be a gmc 270.
___________________________
1959 Apache Short Fleetside,
1959 Apache NAPCO Long Stepside,
1957 3100 with 59 fleetside bed
1957 5700 LCF Crew Cab "Big Bertha",1959 GMC F370
1958 GMC 600, 1946 Chevy, 1959 Viking 60 LCF
1974 Elcamino SS, 1979 6500 GMC Tilt Bed Wrecker
Big Bertha Build
buggy5872 is offline   Reply With Quote
Old 05-28-2013, 04:00 PM   #3
94cummins12v
Re: 1959 gmc 450
Ok well apparently I can't upload pics Name:  IMAG0066.jpg
Old 05-28-2013, 04:03 PM   #4
94cummins12v
Re: 1959 gmc 450
Size:  65.3 KBI might have figured it out
Old 05-28-2013, 04:09 PM   #5
66Submarine
66Submarine's Avatar
Re: 1959 gmc 450
I love it! Nice truck, man. I think a 270 or 302 GMC is what would have came in it originally.
66Submarine is offline   Reply With Quote
Old 05-28-2013, 04:38 PM   #6
94cummins12v
Re: 1959 gmc 450
So how exactly do I go about finding what engine is in it, I want to ditch the oil bath filter and do a decent conical filter with intake tube for a bit more air flow then an hei distributor and since its been converted to 12v some led lights
Old 05-28-2013, 05:04 PM   #7
94cummins12v
Re: 1959 gmc 450
This pic is what I have as of right now if that helps
04 F350 charcoal and chrome, 500hp 6.0l powerstroke
04 GMC Yukon 5.3l with some goodies
1977 Chevy k30 lifted on 37s with sbc 400 and 4 speed
1959 GMC 455v with 10.00-20 tires and 16' dump bed
Old 05-28-2013, 05:34 PM   #8
truckpoor86
Re: 1959 gmc 450
Check the first three numbers on the flat area next to the dissy, probably a 302. Chris
truckpoor86 is offline   Reply With Quote
Old 05-28-2013, 06:28 PM   #9
mr48chev
mr48chev's Avatar
Re: 1959 gmc 450
That is a real workhorse you have. Around here a truck like that would probably have hauled grain to the silo or sweet corn to the cannery.
My ongoing truck projects:
Old 05-28-2013, 06:52 PM   #10
Kim57
Kim57's Avatar
Re: 1959 gmc 450
That's a slick looking truck.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 05-28-2013, 11:57 PM   #11
94cummins12v
Re: 1959 gmc 450
Ok I found some numbers on the driver side of the block it reads like this " GMC 1 232404 B207"
Old 05-29-2013, 09:38 AM   #12
truckpoor86
Re: 1959 gmc 450
The numbers you are after are stamped on the flat boss next to the distributer. The first three numbers tell the displacment of the engine. Chris
Old 05-29-2013, 09:45 AM   #13
mknittle
mknittle's Avatar
Re: 1959 gmc 450
Here is a site that is into the inline engines. I have found quite a bit of info here
http://www.inliners.org/
Here too
http://www.oldgmctrucks.com/
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 05-29-2013, 12:33 PM   #14
buggy5872
buggy5872's Avatar
Re: 1959 gmc 450
That is what I was thinking it would look like. That thing is awsome.....
Big Bertha Build
Old 05-29-2013, 06:01 PM   #15
94cummins12v
Re: 1959 gmc 450
Ok ill go ahead and check by the distributor tonight and go from there, by the way what are the specs on this truck? Gvw, tranny, rear end and whatnot
Old 05-29-2013, 06:45 PM   #16
truckpoor86
Re: 1959 gmc 450
There should be a metal tag attached to the inside of the glovebox door. If it's still there It'll tell you the GVW, trans, rear end, and so on. Chris
Old 05-30-2013, 12:08 PM   #17
94cummins12v
Re: 1959 gmc 450
Ok thanks ill look again tonight I just have to many projects going on right now and keep getting side tracked
Old 05-30-2013, 08:32 PM   #18
_Ogre
_Ogre's Avatar
Re: 1959 gmc 450
that truck is sweet
thanks for posting pics
shop air compressor timer
Old 05-31-2013, 04:29 PM   #19
94cummins12v
Re: 1959 gmc 450
I'm not sure if I want to paint it matte black or what my plan is who ever did the body work years ago bondoed up the natural body lines so its gonna needed sanded down I did a rattle can grey paint job pny 77 Chevy flatbed AMD it turned out good
Old 06-01-2013, 12:59 AM   #20
sqrlnts
Re: 1959 gmc 450
Man, that thing is awesome! I have to say that the grill makes me smile, kinda reminds me of ol Cheech!
sqrlnts is offline   Reply With Quote
Old 06-01-2013, 12:22 PM   #21
94cummins12v
Re: 1959 gmc 450
I defiantly like the body style of this truck better than the 47 Chevy 1.5ton I had
Old 06-01-2013, 06:26 PM   #22
va4cqd
Re: 1959 gmc 450
it was 12 volt from the start
va4cqd is offline   Reply With Quote
Old 06-02-2013, 03:16 PM   #23
lmdangerous
Re: 1959 gmc 450
Its not a 292 (or a 250 or 230 for that matter), Valve cover and intake give it away.Definitely a GMC ingine . Very nice truck . We dont find the larger trucks that nice around here. They usually get run to death- then cut up and scrapped.
lmdangerous is offline   Reply With Quote
Old 06-02-2013, 03:58 PM   #24
OrrieG
OrrieG's Avatar
Re: 1959 gmc 450
Nice truck but may not be original engine, B207 is Feburary 20 1957 casting date on the block. It is possible that GM had engines laying around for a year or so but usually the block date is just a month of so earlier than the assembly date. I know my chevelle was purchased in late august and most of the dated parts are from June and July of the same year.
Old 06-02-2013, 05:45 PM   #25
1972RedNeck
1972RedNeck's Avatar
Re: 1959 gmc 450
Don't they have to let the parts "season" for for a while?
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
