Problem routing exhaust piping past transmission crossmember.(pics)
I'm running into a problem installing my muffler and exhaust piping onto the truck. Basically, on the driver side only, the piping hits the transmission crossmember, not allowing everything to bolt and clamp together. As you can see in the pics, everything gets angled down. Truck has hooker long tube headers and plan is to run 2.5" exhaust. Have collector reducers, race bullet mufflers and turn downs. all in 2.5. Pics are just an example of the problem i'm having, not how i obviously plan on running the exhaust.
![]() ![]() Anyone have any ideas how to solve this? Is there a perticular piece of bent pipe I could use to get the exhaust to clear under the crossmember? Or maybe there are better headers out there that hang low enough to clear the crossmember? or get a all new transmission crossmember? Also what about full exhaust kits like the ones linked below? A full exhaust was my original plan, but had decided on more of a hot rod style by just dumping it right past the cab. http://www.summitracing.com/parts/ho...olet/model/c10 http://www.summitracing.com/parts/wl...olet/model/c10 |
Re: Problem routing exhaust piping past transmission crossmember.(pics)
put a c-notch in the crossmember or let a muffler shop bend a piece to clear it.
![]() Join Date: Jun 2010
Have the exhaust shop bend you a piece so you can run them above the crossmember on the drivers side. You should be able to run under the passenger side. You might have exhaust shop put a small bend for the pass. side too.
Roy 85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818 1987 R10 shortie |
![]() S bend does the trick Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
At the body shop.
Double hump from an earlier pick up.
Early like per 75 or non catalytic converter. Posted via Mobile Device
" That didnt make it any newer " " Dont antique the equipment " |
Take it to a shop and have a proper full exhaust put on it. You will be much happier.
I had mine bent over and around my crossmember, tranny and t-case on both sides. I ran into the same problem with my long tubes. Not the cheapest route, but you'll really be happier.
1976...no...79...Chevy....wait...GMC shortbed 4x4. 5 inch lift on 35s, 355, sm465, daily driver. One day I'll figure out the story in that one. 1957 Chevy long stepper...not sure what I'm doing with that one yet. Awaiting funds I suppose. |
Have them both run above the cross member, keeps it completely out of sight.
Alex. |
GoatLube Experss
![]() Join Date: Oct 2009
I have used these for this same problem befor.
http://www.jegs.com/p/Hedman/Hedman-...44777/10002/-1
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn. '87 R30 dually 454/TH400 '85 1/2 ton CCSB '92 S10 350/350 '84 MonteCarlo 383/PG/9"ford '78 Malibu wagon 350/350 '78 Cutlass (project family car) '96 S10 Jimmy (Moma's) |
#11 | |
They may have used them on later C20 and C30 pickups as well. Posted via Mobile Device
#12 | |
Swapping to earlier trans cross member,cheaper and makes exhaust look and flow better.
Addicted to Rust
![]() Join Date: Dec 2009
My 87 3/4 had the double hump. Jay
Current trucks: (48 GMC100 320 inliner) Gone (48 Suburban in pieces) Sold 87 GMC CCSB 5.3 4l60E Daily Driver ECTA National record holder XO/PP We never really grow up, we just learn how to act in public. |
#15 |
Using a factory transmission crossmember is the best way to go....BUT a few of the aftermarket air suspension guys (such as Porterbuilt and Ekstensive) carry a smaller version of just a single pipe going from frame rail to frame rail that makes it easier to route your exhaust. From $69-$89.
Posted via Mobile Device |
#16 |
On a cheap route I went to the muffler shop on Sun. and looked through there bin and found the bends I needed,they throw away alot of new pipe that are mistakes.I think Heddman makes a ball type collecter than can swivel abit and no need for gaskets.I have them on mine but can,t remeber if they are heddmans
| Bookmarks |
