Old 05-31-2013, 12:16 AM   #1
jcaillouette
jcaillouette's Avatar
Stumped an need help on electronic speedo & 700r4
I've got a 1986 c10 that's carbureted and I recently had a 700r4 out of an 89' Chevy truck and it has electronic speed sensor instead of cable, so I found an instrument cluster out of a 90' suburban with an electronic speedo but now I'm not sure how to get it to work since they say it needs a DRAC but with my truck being carbureted it dont have a PCM so how can I get the electronic speedo to work?
jcaillouette is offline   Reply With Quote
Old 05-31-2013, 12:35 AM   #2
izzy_Britton
izzy_Britton's Avatar
Re: Stumped an need help on electronic speedo & 700r4
i may be wrong but i do not think you can use the e-speedo.
however you could just change the gear on the tail housing to the manual speedo gear and be done with it. if you do get the e-speedo working i would very much like to know how. i also have an 86.
-Izzu
WHO_DCTC - Wifes 05 Z-71 Build - Now defunct as she decided she wants an Escalade too
Cream Puff - LS'd Square - Slow going on the back burner
Tripple Threat - 3 Wrecks for the price of one build thread
Project Delongdium - Step-Sons Plastic Clad 2003 Avalanche - DONE and Delivered.
izzy_Britton is offline   Reply With Quote
Old 05-31-2013, 06:49 AM   #3
sean1969c10
sean1969c10's Avatar
Izzy is right, the easiest thing to do is pull the tail housing off and take the reluctor ring off of the output shaft and install a speedo gear. You will also need a speedo cable drive for the tail housing to go in place of the speed sensor. Good luck.
Sean
"If your gonna be dumb, you gotta be tough"
1960 Chevy Impala Sedan - my 25 year search is over!!
1969 C-10 longbed - Nice day DD
1970 Chevy Nova - Street and Strip Project
2002 Acura MDX my DD
2007 Honda Odssey - My Wife's "Mommy Van"
sean1969c10 is offline   Reply With Quote
Old 05-31-2013, 07:14 AM   #4
jcaillouette
Thanks for the input. There has got to be a way I can make this work. If I bought an autometer speedometer an just connected it to the speed sensor wires would it work properly I wonder?
Old 05-31-2013, 03:54 PM   #5
Mikec10
Mikec10's Avatar
Thats what I did when I had a 5lm60 in my truck, it was a 2 prong speed sensor,
one prong was ground and the other was the signal wire. Now my nv3500 has a 3 prong and I cant get it to work lol. Another option is this
http://www.abbott-tach.com/cablex.htm
1980 C10 SWB Yukon 5.3/5 speed 3.73 gears.
Mikec10 is offline   Reply With Quote
Old 05-31-2013, 08:10 PM   #6
wraprail
wraprail's Avatar
I too would like to hear some ideas. I have a T56, don't mind changing my speedo but dont want to spend a bunch of money. 85 c10 no computer
wraprail is offline   Reply With Quote
Old 06-01-2013, 06:26 AM   #7
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
http://www.dakotadigital.com/index.c...rod/prd126.htm
Tune the signal with this. Jay
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 06-01-2013, 09:43 AM   #8
MalibuSSwagon
You can use an VSS and electronic speedo without a ECM/PCM.
Originally Posted by MalibuSSwagon View Post
GM DRAC/VSSB Calibration
If you are carbed, this is what you need to drive an electric speedo. They are easy to find in 92-95 Chevy/GMC full size trucks, its a white box mounted under the ECM. Make sure you take the pigtail as well.
Easy to wire it too. Just de-pin wires you won't be using and braid together the VSS sensor wires to prevent interference. Connect 12V+ switched thru a 2A fuse, ground, and the C15 VSS output to the speedometer input. Calibrate the box using the method above, and done. Way cheaper ($5 if the junkyard even charges you) and guaranteed to work correctly vs the universal Dakota Digital method for $89.
MalibuSSwagon is offline   Reply With Quote
Old 06-01-2013, 05:25 PM   #9
jcaillouette
Thanks a bunch MalibuSS! I happen to have one of them trucks at my yard that's crashed, I'm gonna try that out!! I will let y'all know the results!!
Old 06-04-2013, 09:27 AM   #10
jcaillouette
Malibu do you know if it matters if the truck is a diesel or gasoline?
Old 06-04-2013, 09:39 AM   #11
MalibuSSwagon
I don't think it would matter, since all 88-98 trucks used an electronic speedometer. If it's a 92-95, and has the white box you should be ok.
Old 06-04-2013, 10:17 AM   #12
bilfman
bilfman's Avatar
There is a unit called Cable-X it converts the electronic signal to mechanical . Runs about 300 and comes with a new short speedo cable. This keeps the stock dash and speedo.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 06-04-2013, 10:33 AM   #13
hyatt
They make gps speedos now Dont have to hook to trans at all
1946 car hauler
1948 surburban
1937 chevy sedan
1940 olds sedan (project)
1967 ss396 chevelle
1999 dually crewcab(24000 miles)
hyatt is offline   Reply With Quote
Old 06-04-2013, 01:57 PM   #14
carboncrew
carboncrew's Avatar
another source....jagsthatrun.com a call or check out their webpage
http://jagsthatrun.com/Pages/SpeedSe...eedometer.html
carboncrew is offline   Reply With Quote
