Old 11-23-2003, 10:09 PM   #1
frost89434
frost89434's Avatar
Need good used 68-71 style big block motor mounts
Just like the title says. I need the motor mounts and all hardware. I have the towers. I would like to find used because I just don't see paying $150 for new ones. Any help would be great. Thanks jim
68 short fleet with 71 front clip 2wd jaguar blue
99 chevy ext cab shrtbed z71 loaded
99 chevy swb fleetside(daily driver)
Sparks, Nevada
frost89434 is offline   Reply With Quote
Old 11-23-2003, 10:26 PM   #2
72shadetree
KEEP ON TRUCKING
72shadetree's Avatar
if you have the towers the mounts shoud be the same as a sb about $8 apiece at your local auto parts
72 cheyenne 2wd lwb
71 k20 sons
bassett va
72shadetree is offline   Reply With Quote
Old 11-23-2003, 11:21 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Yep, small block mounts. For the rubber piece underneath the frame stand that the bolt runs through, I used an extra set of core support biscuits. Total cost of everything was about 35 bucks, new.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 11-24-2003, 08:07 PM   #4
frost89434
frost89434's Avatar
TTT
Sparks, Nevada
Old 11-24-2003, 08:25 PM   #5
Tx Firefighter
I guess mine and shadetree's answers aren't what you're looking for?
It worked great for my big block.
Old 11-24-2003, 08:43 PM   #6
72shadetree
KEEP ON TRUCKING
sorry how i worded it wasnt trying to say that sb will work instead of bb.
the sb and bb use the same mount just different towers for 68-71
72 style was totlly different both mounts and towers
the mounts new are around $8 apiece 2 needed
the hardware i forget the size consist of 3 bolts each side to block and 1 on each side for mount to tower for a total of 8 short bolts 4 around $2 at hardware
around $20 not $150
72 cheyenne 2wd lwb
71 k20 sons
bassett va
Old 11-24-2003, 10:05 PM   #7
frost89434
frost89434's Avatar
Thanks for the input. That's probably what I am going to end up doing I just thought I'd check to see if anybody had any laying around. Thanks JIM
Sparks, Nevada
Old 11-24-2003, 10:10 PM   #8
Blue4x4
Blue4x4's Avatar
TTT
Blue4x4 is offline   Reply With Quote
Old 11-24-2003, 10:14 PM   #9
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Small block and 68-71 BB motor mounts are not the same. You may be able to make it work, however the Big Block motor mounts are both larger and stronger. WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 11-24-2003, 10:34 PM   #10
frost89434
frost89434's Avatar
Thanks Wes
Sparks, Nevada
Old 11-24-2003, 10:43 PM   #11
Classic Heartbeat
Your welcome. WES www.ClassicHeartbeat.com
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
