Old 11-24-2003, 09:31 PM   #26
Nate003
thanks guys, i figured out that i need to go with this bracket, if anyone has one laying around and willing to sell, let me know, thank you, Nate
Nate003 is offline   Reply With Quote
Old 11-24-2003, 09:44 PM   #27
gregsplace
gregsplace's Avatar
Nate, in your pic, the 2 outer brackets are alternator brackets(right one bolts to front of exhaust manifold), the 2nd from the left is a lower p/s cradle bracket for long water pump, the 3rd bracket is an early p/s cradle bracket that will not work on 4-bolt main 350's with the larger damper. hope this helps. The set on the "green barrel" is what you need, usually go for at least $20 and up..ebay, here, etc I'd sell you some if I had them, sorry Greg
67 3/4 4x4 402,a/t,flat bed
98 GMC Sierra swb daily driver
87 burb parting out.
68 1/2 chevy, 350/350, 71 gmc frame, kid's beater
69 1ton 396-4sp, dump
69 swb stepside 396/400th current frameup
67 swb 454/400th rebuilding now, oldest boy just rolled it
99,HD, Road King Classic
Colwich Ks
gregsplace is offline   Reply With Quote
Old 11-24-2003, 10:02 PM   #28
Nate003
thanks for the info greg, that's why i come to the board, for the knowledge of others.
Old 11-24-2003, 10:31 PM   #29
70ChevyLongbed
Howzit?!?
70ChevyLongbed's Avatar
About the Pic...
Tx Firefighter,
Should you check about royalties from your Pic?
Jason
Hawaiian-J
70 Longbed, 307, Edelbrock Carb 1404, Edelbrock Intake 2101, Dual Roller Timing chain and gears, 214/214 cam, Comp Roller Rockers, dual Flowmasters.
1999 Chevy Tahoe
2004 Mini Cooper S
71 BMW 2002 - Sold
70ChevyLongbed is offline   Reply With Quote
