Old 05-31-2013, 07:59 PM   #1
JMac11
JMac11's Avatar
4x4 Crossmember
Not shilling these in anyway...... just a heads up. Not compatible with stock 5.3 compressor, so I am probably not a player......
http://dirtydingo.com/store/pages.php?pID=19&CDpath=0
JMac11 is offline   Reply With Quote
Old 05-31-2013, 10:51 PM   #2
6600DURAMAX
6600DURAMAX's Avatar
Re: 4x4 Crossmember
Those are sweet, I am have been contemplating a LSx swap for a while.....this could be the first piece!!!! What would you have to do to run a/c???
1972 K5 - LS3/408 (595Hp) -6L80e-One Tons with 4.56, 20'' Beadlocks with 37'' rubber, full TMI interior, JL Audio .....
1971 CREWMAX Build.....at body shop for couple more years
6600DURAMAX is offline   Reply With Quote
Old 05-31-2013, 11:08 PM   #3
truckdude239
truckdude239's Avatar
Re: 4x4 Crossmember
They sell a relocate kit that movez the ac up high
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 05-31-2013, 11:19 PM   #4
6600DURAMAX
Re: 4x4 Crossmember
Wow, a/c relocate kit is more than the engine mounts
Old 06-01-2013, 08:40 AM   #5
Thealien
Thealien's Avatar
Re: 4x4 Crossmember
ANOTHER OPTION
Old 06-01-2013, 11:55 AM   #6
JMac11
JMac11's Avatar
Re: 4x4 Crossmember
Had seen those, prob not a much difference structural strength wise. Anyone know who might have use the Pacific Fab one???
Old 06-01-2013, 01:29 PM   #7
Crash_OK
Crash_OK's Avatar
Re: 4x4 Crossmember
I did...
http://67-72chevytrucks.com/vboard/s...&postcount=122
I had to remove it after the install because the oil pan was too close to the cross member. I removed it and sent it back to have it fixed. I should have just fixed it myself. All they did was hit it with a cutoff wheel and then throw some paint on it. They claim they have never seen the issue I had before. If I had to do it over I am not sure I would have gone with the PF cross member.
Mark
Crash's 69 4x4 SWB
Crash's Roof over Lake Home
Crash's 1988 Land Cruiser Build
Crash_OK is offline   Reply With Quote
Old 06-02-2013, 09:58 AM   #8
Thealien
Thealien's Avatar
Re: 4x4 Crossmember
Here is one member using it without any issues (except his pictures don't load anymore)
Firebirdjones
Gunny Davis lifted his 2 inches to clear
Another installation that had to be tweaked
I made my own so I have no experience with either. I just want to help give everyone options. I don't think any of these swaps will be without some level of fabrication skills. Good luck with your build
Old 06-02-2013, 12:28 PM   #9
JMac11
JMac11's Avatar
Re: 4x4 Crossmember
I wish DIY would do an LS Crossmember, like their stuff but????
In a perfect world I think I would do this:
The C channel from the DIY4x4 crossmember with a CPP universal LS Engine mount. I would get the channel undrilled, narrow the CPP mount, drill the C channel for the CPP mount. Then use existing frame holes to mount c channel permanently, if needed drill new frame holes.......
http://www.classicperform.com/Store/...cks/4810LS.htm
Old 06-03-2013, 03:38 PM   #10
JMac11
JMac11's Avatar
Re: 4x4 Crossmember
Good Stuff.. Thealien, when you modified your DIY crossmember, did the distance between the mounts change? I have one of thos and that would probably be my best deal, my K5 is lifted so interference would not be a problem.
Josh
Old 06-10-2013, 09:23 AM   #11
JMac11
JMac11's Avatar
Re: 4x4 Crossmember
Ordering something today!!!!
Old 06-10-2013, 04:51 PM   #12
Thealien
Thealien's Avatar
Re: 4x4 Crossmember
Josh
Sorry I didn't see this but most of the info is in my few threads. I could not get the DIY 4X4 crossmember to work even though they tried a few times and did not overcharge me for their time.
I ended up using the C channel, the plates that bolt to the C channel, the engine mounts and brackets.
From there I fabbed up some 1/4 wall 1 1/4 inch chrom molly tubing and joined everything together. It was a pain but worked fine for me. Wanting to stay at stock ride height added to my issues.
http://67-72chevytrucks.com/vboard/s...d.php?t=375380
Here you can see the template I made
