Old 06-01-2013, 03:55 PM   #1
1tuff71
1tuff71's Avatar
column shift pin
Anyone know what size pin holds the shifter in the column. I tried a 3/4 pinch pin and its a bit too big and 3/16 is too small. WTH ?? PO had a nail in there and that don't fly.
1tuff71 is offline   Reply With Quote
Old 06-01-2013, 07:05 PM   #2
clemsonteg
Re: column shift pin
This pin?
http://www.classicparts.com/1967-94-.../#.Uap87mt5mSM
clemsonteg is offline   Reply With Quote
Old 06-01-2013, 09:10 PM   #3
1tuff71
1tuff71's Avatar
Cool Re: column shift pin
yea I think that could be it and I have their catalog but some how missed it. Thanks dude. $8.00 bucks I hope its gold plated !
Old 06-04-2013, 04:09 PM   #4
luvbowties
luvbowties's Avatar
Wink Re: column shift pin
To save the $8 ++, find a drill bit whose shank fits. Cut--grinder--shank to proper length. Friction should hold it in. A hint to get a tighter fit would be to use a numbered set to find the precise size you want. 89 cents vs $8? Yep, I'd do that!
HTH,
Sam
luvbowties is offline   Reply With Quote
Old 06-04-2013, 05:25 PM   #5
Mint68
Mint68's Avatar
HTH,
Sam
That's a good idea, I think I will try that cause my shifter is a little wobbly as well.
Mint68 is offline   Reply With Quote
Old 06-04-2013, 08:51 PM   #6
luvbowties
luvbowties's Avatar
Exclamation Re: column shift pin
Remember the end of shifter arm has a spring on it.
Sam
