#76 |
Re: 1985 chevy lift kits
If they put in the drop arm,they should have taken the time to center the steering wheel.I hope these guys didn't soak you too bad on the install,I would go over your U bolts and any other nuts & bolts they had off or replaced and re torque then after a 100 miles or so...They should have fixed that vibration before it even left the shop...
1977 Chev C30 454/465/14ff DRW 1974 Chev C20.350/465/14ff " Rock n Roll ain't noise pollution"
#77 |
Well once I get the front end alignment done ill tell them about the vibration in the rear end.
Yea im a bit bummed out that I can't get the truck back right the first time Posted via Mobile Device |
#78 |
Video will be posted later tonight guys I hope you all like the truck !
#79 |
#80 |
Clean truck!!! It looks like the the dropped ain't quite enough, the draglink should be parallel with the ground, looks like yours is higher at the pitman arm. Maybe it will level out as the springs settle. Also, forgot you got a shackle flip, the points the pinion towards the case, so shouldn't be the problem. Are the u-joints in good shape?? How bad is the vibe? When does it do it? Could be just a simple joint replacement....
2000 Chevy Tahoe Limited 3/5" drop 2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon stock SAS 6" |
#81 |
Just when I lay into the gas it feels slight vibe. Ujoints will be cheap easy fix it that's the case. I still have to go get the front end corrected. Just haven't had time because of work
#82 |
i could definately see 35's on rallyes rubbing with a 4" lift under extreme flex. heres my 85 on 33s and my 80 crew with 37s. no lift but some trimming, the 1 ton has a lot, including inner fender work.
80 k35 3+3 DD (big dirty) 85 k1500 DD (scottsdale) and then a few more |
#83 |
forgot to attach the 1 ton pic, the rusted out fender sits perfect when the truck is level lol that crew cab frame has a ton of flex lol
#84 |
So the tire guy is 95 percent sure 35s will fit on a 16 inch rim that I picked.. he said worse case scenario we put them on they don't fit I can just get a 33 I ended up liking the toyo open country mud tire.
#85 |
if you stay with a narrow rim with stockish offset it might fit....
#86 |
11 degree offset 12.5 widths
#87 |
good choice of tire! you won't be disappointed. for playin' i have swampers, for everything else, i use my open country M/T's
| Bookmarks |
