Oil and Temp guage
Hey guys,
I just have a few couple questions on my truck I haven't really worried about it, as my truck has seem to run fine, and still is. It's a SBC 305 with headers and true dual exhaust, my question is my temp gauge isn't even working, and I was going to put new gauges but changed my mind and I had taken a few gauges out. One was my oil PSI gauge, well now that's reading when the truck is off at 60 and when I turn it on and it starts to warm up it'll go read up to 120 which I know for a fact is a misread because it was working fine until I had pulled the gauges. My question is how can I trace to check if my temp gauge works, and same for my oil pressure gauge? Thanks for all the help in advance fellas you guys rock and are always so helpful.
Korwin 77 C10 Silverado Sharkbite LWB Build 67 Chevy C10 Frame Off 06 Dodge Magnum 2.7v6 aka swag wag! 2010 Honda Accord 2.4I4 DD aka Liquid Metal |
Re: Oil and Temp guage
For the temp gauge: Put you green temp wire to the frame a have someone look at your gauge if it pegs. If so, you sensor is probably shot. If not, it can be the wire or the gauge. Run down your wire or do a measure.
For the oil gauge. It can be that the pointer has been touched. Try gently to push it back to it's 0 position when the engine is off. |
#3 | |
Okay great! Thanks for the quick response man I appreciate it!
78K & 79C Jimmys
when my 78 cluster swap both had power and no senders yet
the oil was high when the sender was off temp stayed low when the sender was off I'd start checking the power back there look for the +and - for the cluster you can see issues my 79 4X4 had with rusty connections and bent paths
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
#5 | |
I really think my temp gauge is bad or the wire has burned up somewhere, reason I'm lead to believe this is because I do have a single green wire that has like an end cap on it and I've put it to my block and ran my truck it didn't move one bit, so I'm thinking either the wiring or gauge is completely bad.
The green wire supposed to go to the sensor in the drivers side head, between cylinder 1 and 3.
#7 | |
![]() Posted via Mobile Device
| Bookmarks |
