Old 06-04-2013, 07:45 PM   #1
bennetth27
Help on New Gauge Cluster with Auto meter Gauges
Hey Guys new to this site and just got a 70 c10 step side shortbed to spend my money on. I want to pull the gauge cluster out and put new one in with auto meter gauges. This includes adding a tach that is not there now can anyone help me with what all needs to be done to do all of this your help and advise will be Great thanks!
bennetth27 is offline   Reply With Quote
Old 06-04-2013, 08:21 PM   #2
Tinkermc
Re: Help on New Gauge Cluster with Auto meter Gauges
several views here on this very subject, welcome to the forum!!!!
Tinkermc is offline   Reply With Quote
Old 06-05-2013, 06:42 PM   #3
bennetth27
Thanks You guys will probably get tired of all my Questions by the time I get thru with this project Just trying to keep the Clasics alive!
Old 06-05-2013, 06:48 PM   #4
71' Custom
71' Custom's Avatar
I did just what you are trying to do, it is not hard at all, you will need to shave the holes a little and just make sure you have your wiring figured out. I had rewired my whole truck at the time with the painless kit, made it real easy.
..........___
..____//_{)] ______
[_(O)_[___][__(O)_]
Project: Under Pressure II
http://www.67-72chevytrucks.com/vboa...d.php?t=559720
71' Custom is offline   Reply With Quote
Old 06-05-2013, 07:06 PM   #5
bennetth27
This is just what I want to do looks Great! I am Just not very good at electrical! How hard was it to install the painless wiring!
Old 06-05-2013, 07:17 PM   #6
71' Custom
71' Custom's Avatar
The painless kit I did rewired the whole truck, gives you wiring for power windows, locks seats, everything. I was able to do the entire kit in under 2 days. Every individual wire is labeled over and over from end to end. Very user friendly kit. Word of warning though, where the fuse block goes through the fire wall, you have to cut the hole bigger.
..........___
..____//_{)] ______
[_(O)_[___][__(O)_]
Old 06-05-2013, 07:20 PM   #7
71' Custom
71' Custom's Avatar
Also I put led's in them too. Although, now I am going to have to change them to blue les's.
..........___
..____//_{)] ______
[_(O)_[___][__(O)_]
Old 06-05-2013, 07:22 PM   #8
71' Custom
71' Custom's Avatar
But, if you don't want to rewire the whole truck, just go get a Chilton's manual. It has all the wiring diagrams.
..........___
..____//_{)] ______
[_(O)_[___][__(O)_]
Old 06-05-2013, 07:31 PM   #9
bennetth27
Thanks Man good info! I will probably go this route more than likely needs rewiring anyway!
Old 06-05-2013, 07:38 PM   #10
bigbadchev72
People know me
bigbadchev72's Avatar
I have a full autometer setup in my blazer. I used 3 sets of the flat 4way trailer wiring connectors and plugs and then wrapped some colored electrical tape on the connectors to keep them from getting mixed up. That way if I need to remove the cluster I can easily.
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels
1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels
bigbadchev72 is offline   Reply With Quote
Old 06-05-2013, 07:43 PM   #11
vegadesign
vegadesign's Avatar
Originally Posted by 71' Custom View Post
Attachment 1116502
i want it lol
need for the green in mine
"its not a hobby, It's a Lifestyle"
bagged and soon to be bodied 70 longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=564028
vegadesign is offline   Reply With Quote
Old 06-05-2013, 07:44 PM   #12
SpaceForRent
SpaceForRent's Avatar
I just put all new autometer gauges in, looks dead sexy and was actually pretty easy.
I went with Electric gauges, had to remote mount the oil pressure sending unit on the frame rail as there was not enough clearance between my block and headers (454)
The Tach was the second easiest - Just one wire to the ignition (I have MSD ignition, so that helps)
Easiest was the voltmeter - just run power to it!
Loads of info on here and other sites.
I used a billet aluminum bezel and so I had to cut two tabs in my dash
SpaceForRent is offline   Reply With Quote
Old 06-05-2013, 08:00 PM   #13
john
member #16
john's Avatar
Welcome to the forum bennetth27, Here's a link to some diagrams.
http://67-72chevytrucks.com/vboard/s...d.php?t=185856
john is offline   Reply With Quote
Old 06-05-2013, 08:04 PM   #14
bennetth27
With the painless wiring do I still use manual gauges or electrical?
Old 06-05-2013, 08:06 PM   #15
SpaceForRent
I would go with Electric, but that is personal preference.
-You can get a tach easy
-Easier to calibrate spedometer
-No oil line running into your cab
Old 06-05-2013, 11:35 PM   #16
71' Custom
71' Custom's Avatar
Originally Posted by vegadesign View Post
i want it lol
Actually found those LED's at a local napa
..........___
..____//_{)] ______
[_(O)_[___][__(O)_]
Old 06-06-2013, 06:01 PM   #17
bennetth27
Thanks guys for all the info helped greatly!
