Re: AC high pressure cut out switch needed or not?
Here is the compressor switch. I tapped into the green wire to trigger my electric fans to come on. I am using a painless wiring electric fan kit that kicks on off of a temp sensor or when the ac is turned on.
Posted via Mobile Device Posted via Mobile Device |
You don't need a high pressure switch. Most compressors have a high pressure relief valve if the pressure gets too high. If you don't have one just pick one up and install it. Help keep the clutter under the hood neatened up as well. Is there a specific reason you want to install the high pressure switch?
But if you want to ...
