Old 06-06-2013, 08:16 PM   #1
Kim57
Kim57's Avatar
Air Compressor
Picked this up for $50.
Needs a little TLC but runs fine.
"Made in the U.S.A."
I've been wanting a larger one for years and got lucky with this find.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 06-06-2013, 08:30 PM   #2
Bubba54
Re: Air Compressor
Kim, nice find !!
Bubba54 is offline   Reply With Quote
Old 06-06-2013, 09:17 PM   #3
_Ogre
_Ogre's Avatar
Re: Air Compressor
you'll wonder how you ever got along without it
9.5 cfm @ 100 psi is nice, i think mine is rated 10 cfm @ 80 psi
it probably cuts down to 5 cfm @ 100 psi
yours will pump up a lot quicker
shop air compressor timer
Old 06-07-2013, 12:04 AM   #4
arturo7
arturo7's Avatar
Re: Air Compressor
$50? Damn, I thought I did good picking up 5HP/60G for $200.
ever forward
build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=542073
arturo7 is offline   Reply With Quote
Old 06-07-2013, 04:05 AM   #5
Daze57
Daze57's Avatar
Re: Air Compressor
great find !!! good luck with it --$50 ? wow!!!!
Daze57 is offline   Reply With Quote
Old 06-07-2013, 09:22 AM   #6
mr48chev
mr48chev's Avatar
Re: Air Compressor
That is sweet, I think it is a predecessor to this one or the rated below this one http://www.grainger.com/Grainger/SPE...E99?Pid=search
At any rate it was sold new at Grainger and you still should be able to order parts from Grainger.
My ongoing truck projects:
Old 06-07-2013, 09:59 AM   #7
Kim57
Kim57's Avatar
Re: Air Compressor
I was looking on their site for it.
I think it's an older model but will work just great in my garage.
Kim
My build thread
Old 06-07-2013, 11:53 AM   #8
Rude Dude
Rude Dude's Avatar
Re: Air Compressor
Great find Kim
Whats good is you can buy relacement parts real easy. The compressor I bought the PO said it keep popping the house breaker, if by chance it blows a breaker check the copper tube that goes from pump to tank there is a valve at tank. It is easy to cahnge, this one way valve sometimes stick lube with WD40 or replace it is cheap enough. No more problems with mine after I did that.
Rude Dude is offline   Reply With Quote
Old 06-07-2013, 01:10 PM   #9
Kim57
Kim57's Avatar
Re: Air Compressor
Originally Posted by Rude Dude View Post
Great find Kim
Thanks for the info.
Kim
My build thread
Old 06-07-2013, 02:07 PM   #10
Dan in Pasadena
Dan in Pasadena's Avatar
Re: Air Compressor
Wow! $50??!
I thought I did well finding a used 60 gallon Harbor Freight POS for $250 a year ago.
Dan in Pasadena is offline   Reply With Quote
Old 06-07-2013, 03:39 PM   #11
mr48chev
mr48chev's Avatar
Re: Air Compressor
Kim
It is an older model but you shouldn't have a problem getting parts for it when you need them. I think you lucked out big time on that one.
If you to to the "local" air compressor shop they won't laugh at you when you ask for parts for it or want to have it worked on if needed.
Old 06-09-2013, 09:43 AM   #12
Divine 59
Re: Air Compressor
Smoking deal...sure you weren't packing a gun when you made the deal with the previous owner?
Divine 59 is offline   Reply With Quote
Old 06-09-2013, 01:14 PM   #13
Dan in Pasadena
Re: Air Compressor
...If you to to the "local" air compressor shop they won't laugh at you when you ask for parts for it or want to have it worked on if needed.
Because Mr 48 is a nice guy he left out, "Unlike Dan..." Lol.
