Closed Thread
Old 06-06-2013, 03:47 PM   #7826
el_bole
Re: What did you do to your truck today?
Great work Gents(and ladies if any),
Finally Finally solved my tahoe rear end and '73 brake lines issue....
Went through about four different companies with no avail to get the main brake line from the 99' Tahoe to "marry" up to the 73's brake line...
Finally someone at one of said companies recommended I go to a Local shop here in San Diego and the Gates of Heaven Opened up LOL.....
For the first time I didnt see a head being scratched or someone saying; "my computer tells me we dont have such a part" ARGH! Nope this old school pro probably with a ton of know how and experience says..."No big deal Ill have it done in two days"......I was shocked, elated, jumping up and down for Joy...ok the last part didnt happen.
These masters of the Arts of mechanic and custom are a dying breed I hope some of the young guys soak up as much knowledge from these types of folks as possible...
Pics attached of the Master piece that married together GM of 1973 and GM of 1999.....Oh and I mocked up a mid eighties camaro steering column on my 61 cab....Ill be searching on Forum to see how some of you mounted later model columns to 60-66 cabs....(ANY INFO would be appreiciate)
Keep up the great work and progress!!!!
el_bole
el_bole is offline
Old 06-06-2013, 05:28 PM   #7827
kieth
kieth's Avatar
el_bole
HERE ARE PICTURES OF HOW WE MERGED A 91 TILT COLUMN OUT OF A 91 BURB IN MY 66 GMC.
KEEP CLICKING ON THE THUMBNAILS TO SCROLL THROUGH WHEN YOU HIT THE LAST THUMBNAIL SHOWN CLICK ON NEXT AND IT WILL GO TO THE NEXT GROUP OF THUMBNAILS. KIETH
http://kieth.smugmug.com/Trucks/66-G...3720&k=WSB2DjV
kieth is offline
Old 06-06-2013, 07:00 PM   #7828
el_bole
Kieth...
Amazing Job on your 66 with the 91 steering column....
I would have never thought of putting(welding) the brackets together!!
Ingenious....Thanks for the information...will definetly be doing something similiar on mine.
Thanks again,
el_bole
el_bole is offline
Old 06-07-2013, 05:11 PM   #7829
robber grin
Got my 62's frame cleaned and primed... ran out of gray and well... nothing some black runnoleum won't cover.
rg
robber grin is offline
Old 06-07-2013, 06:51 PM   #7830
williamsboys
williamsboys's Avatar
Completely gutted my cab.
http://
Williamsboy
williamsboys is offline
Old 06-07-2013, 07:23 PM   #7831
Coboyle04
Coboyle04's Avatar
Chuck
Coboyle04 is offline
Old 06-07-2013, 07:49 PM   #7832
donthekawguy
donthekawguy's Avatar
Originally Posted by Coboyle04 View Post
Very nice! 4BT?
66 shorty
donthekawguy is offline
Old 06-07-2013, 09:37 PM   #7833
endlessearth
endlessearth's Avatar
Mounted a handbrake boot that I felt lucky to score. I had to make a lot of calls to find it. It resulted in an impressive improvement in lowering interior noise and keeping heat and smell out. It used to just pour in from the open hole.
My buddy Chip came up in his cool old wagon and installed a new rag joint. Chip is a wealth of know how and ability on old cars and trucks. The 48 year old original rag joint was really shot and a little horrifying to look at considering how many miles I recently put on it. Easy 50% improvement in steering efficiency. New front shocks and an oil filter conversion completed the day. It was 110 here in Scottsdale. Hot day to be under the truck for 5 hours. Tomorrow it gets a tune-up and some new parts on the top end.
endlessearth is offline
Old 06-07-2013, 09:52 PM   #7834
Coboyle04
Coboyle04's Avatar
Originally Posted by donthekawguy View Post
Very nice! 4BT?
thats exactly right....soon to hit the streets
Chuck
Old 06-08-2013, 12:52 AM   #7835
gofastnut
gofastnut's Avatar
Slapped some paint on her Wednesday in hopes of driving it in the Fair Parade today. Performed tune-up, went to set timing and found my fuel pump was leaking
Got a fuel pump today, ran(drove the grocery getter) home on lunch and replaced fuel pump, changed oil--3 gallons of gas/oil in the crankcase, and set timing. She runs SO much better now!
I gotta tell you, seeing all you guys working on your stuff got me motivated, you guys ROCK!
Jeff
96 C3500 Crew Cab Long bed (Waiting on Cool Name)
64 C-10 shortie stepside, "Ole Brownie"
C-10 Club
My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345
gofastnut is offline
Old 06-08-2013, 01:36 AM   #7836
mud.man.rj
mud.man.rj's Avatar
Changed my dash cover tonight and installed a Monster tach, will post pic's tomorrow.
mud.man.rj is offline
Old 06-08-2013, 01:43 AM   #7837
hopped up
hopped up's Avatar
I like the handbrake right there! Wish mine was stickshift
hopped up is offline
Old 06-08-2013, 10:09 AM   #7838
LT1 Burb
LT1 Burb's Avatar
Opened the hood to change my header gaskets and saw how much work it was going to be and closed the hood again. I guess I will wait until winter.
LT1 Burb is offline
Old 06-08-2013, 12:30 PM   #7839
anubisani
anubisani's Avatar
if you use orange RTV around the ports before u install the gaskets they never leak apply enough to fill out uneven parts. I drag race and that's what we do even on the flange g
gaskets
anubisani is offline
Old 06-08-2013, 01:44 PM   #7840
ChrisDollins
ChrisDollins's Avatar
Finished up the disc conversion on my 66. Took a lot longer than expected, but it is my dd, so that made it tougher.
Chris
ChrisDollins is offline
Old 06-08-2013, 08:20 PM   #7841
robber grin
My son and I "Finished" priming and painting the 62's chassis.
rg
Old 06-08-2013, 08:36 PM   #7842
Reyals Bemus
The chassis looks fantastic. What did you paint it with?
Reyals Bemus is offline
Old 06-08-2013, 08:56 PM   #7843
WCHLVR
WCHLVR's Avatar
Not so much a "do to" as it is a "do with". Last night I got to use it as a picnic table for the BBQ we had at the shop-
We ended up with like a dozen cars/trucks showing up!
WCHLVR is offline
Old 06-08-2013, 09:39 PM   #7844
robber grin
THANKS!
We just rattle-canned it with Rustoleum gray primer then Rusto's Pro-Series Gloss Black.
rg
Old 06-08-2013, 09:41 PM   #7845
62 Barnfind
62 Barnfind's Avatar
Did my first test drive in my 62!
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline
Old 06-08-2013, 10:26 PM   #7846
jayoldschool
Moderator
Congrats! I'm really liking how that paint turned out.
jayoldschool is online now
Old 06-08-2013, 10:28 PM   #7847
FetchMeAPepsi
FetchMeAPepsi's Avatar
rg
Looks great! Father son team makes it all that more fun!
Sweet looking truck!
Sometimes you just gotta
Sack up! Eat that elephant one bite at a time.
Today and yesterday I did nothing but drive my truck to the hardware store. It was great! Sadly the fun was interrupted several times by arriving at my destinations. And I swapped struts on the wife's car. Tore the end of my middle finger off. I hate that car. My truck never tore anything off of me but a frown.
Well, and my shirt. Once. But no one needs to know about that.
She's a right feisty little vixen.
Step by steps:
Remove primer to reveal original paint
Rebuild a carburetor
See My Build - Cecilia!
Some people are like slinkys. Not worth much but funny as heck when pushed down stairs.
FetchMeAPepsi is offline
Old 06-08-2013, 11:47 PM   #7848
Trsmotrhed
Trsmotrhed's Avatar
Finished sanding my bed side. Looks great. My arms are wore out. Beer time now.
After.
Before.
Sold the 63 and have a 68 now.
63 SWB C10
LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18
http://67-72chevytrucks.com/vboard/s...d.php?t=544174
Trsmotrhed is offline
Old 06-09-2013, 12:23 AM   #7849
mud.man.rj
mud.man.rj's Avatar
That is some nice work on the bedside.
Old 06-09-2013, 02:51 AM   #7850
mattbert56
mattbert56's Avatar
today went and bought all my trim, wind shield wipers, and an original ignition switch for 100 bucks @ cream's today for the 65. also talked to the manager and we made friends, let me trade my old door handles for the ones he had in the lot. one off trade. good man.
mattbert56 is offline
Closed Thread
