Closed Thread
Old 06-07-2013, 12:09 PM   #2351
Rude Dude
Rude Dude's Avatar
Re: What Did You Do With Your Truck Today ?
Looking good !
Originally Posted by dubie View Post
Lights and grill got installed. I also bolted the tranny hump down and installed the B&M ratchet shifter
Rude Dude is offline
Old 06-07-2013, 07:43 PM   #2352
davecarney2
davecarney2's Avatar
Few days ago ordered complete Porterbuilt set up for my 59. Got the first email today that some steering components are shipped. I dont come home from deployment for 2 more months its gonna be like Christmas when I get home. Cant wait to see the Porterbuilt stuff in person!!
davecarney2 is offline
Old 06-07-2013, 11:17 PM   #2353
taotaoali
finished installing my windsheild with the deluxe trim, and started installing my doors (after getting the first one hung I realized I cant effectively adjust the door alone, will put that one off until i can get help.
taotaoali is offline
Old 06-07-2013, 11:30 PM   #2354
Dan in Pasadena
Dan in Pasadena's Avatar
So...you're obviously NOT talking to us from North Carolina....where are you? Clue us in if you can. What's it look like out the door from you?
PS: Thanks for serving.
Dan in Pasadena is offline
Old 06-08-2013, 12:02 AM   #2355
yossarian19
I stopped by the truck (it lives at work, not home) and got the front calipers plumbed up, wheels bolted on & greased the freshly-assembled steering.
I also walked around the truck & threw out all the old parts boxes, misc. scraps, packaging etc and got the greasy rags into a single pile.
Still have to plumb the rear brakes, find out what's dripping in the brake plumbing (!), bleed the system and attach intermediate shaft to column, then column to floor. Then the body work goes back on.Once that's all done, I'm leaving the truck alone till after I move this September.
yossarian19 is offline
Old 06-09-2013, 10:11 PM   #2356
la hi
I gave up on getting out the old kingpins and hired it out. I got the 57 back today and the steering is smooth, does not wander at 85. I think I trust it now to be the daily driver.
The spring shocks on the front were compressed and now the front suspension is tight. Maybe this is how the 57 drove when it was new? So far I have a straight axle, speedway disc brake conversion, sway bars, spring loaded shocks, and new kingpins all with a heavy 454ci.
I must look at the front disc brake conversion (drum rears) as I step on the pedal it takes a long time to stop. I can pump the brakes and it stops faster. I changed to a 15" steering wheel and the steering is easier to control.
la hi is offline
Old 06-10-2013, 12:43 AM   #2357
NEWFISHER
NEWFISHER's Avatar
Thought about changing the oil but it got hot here and I hauled 6 people and the boat to the lake.
NEWFISHER is offline
Old 06-10-2013, 02:02 AM   #2358
RedneckRodder
RedneckRodder's Avatar
Bought a 3 core radiator (designed for a chopped down '32 F!*#), a new flex plate and a bunch of chrome goodies for the truck today. Oh, and a drive line from Pickn'pull so I wouldn't have to pay to have the one I already had extended and balanced. Hard day for the bank account, but my shop will look like Christmas morning in about a week!
RedneckRodder is offline
Old 06-10-2013, 09:17 AM   #2359
mknittle
mknittle's Avatar
Gotta love the burbs!
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline
Old 06-10-2013, 08:36 PM   #2360
yossarian19
Got off work early and trimmed the steering column down a bit, ground new 3/4 DD flats onto it & got the intermediate shaft installed. Then ground out & installed the floor plate. Still need to drill for grub screws to secure it, but when I turn the wheel the tires move. All thats left is one or two brake flares & hose mounting tabs, I'm done for the summer.
Old 06-11-2013, 02:04 PM   #2361
focusedontheprize
focusedontheprize's Avatar
Tim (dubie) - loving the look of the truck. That shop truck theme is a perfect theme.
Well my Thurs and Fri off from work turned into me taking Mon off also. Very busy weekend. Unfortunately no pictures right now, they are all on my camera.
Wheels and tires mounted and bolted on
Hood is on, but needs adjustment
Headliner, insulator mat, and rubber mat are in
Door glass in
Door handles installed and locks keyed the same and installed
Weatherstripping installed
Wiring is 95% done
This weekend I am building an exhaust and I swear I will drive this thing before Sunday at 7pm even if it is just out of the garage and back in.
focusedontheprize is offline
Old 06-11-2013, 02:20 PM   #2362
buggy5872
buggy5872's Avatar
Headed home to dump the tranny out of Big Bertha. Aparently the stock torque converter does not like the 454 and 18k pounds. Chuncks of the clutch plugged the cooler....twice. Made it home though. Tranny temp was at 298 when we checked it. So that ones a little fried. Headed out camping again this Friday. Lucky I got a spare tranny with 1000 miles on it. Now my buddy can use this one to build a better one. Should have it going again in a couple hours.
___________________________
1959 Apache Short Fleetside,
1959 Apache NAPCO Long Stepside,
1957 3100 with 59 fleetside bed
1957 5700 LCF Crew Cab "Big Bertha",1959 GMC F370
1958 GMC 600, 1946 Chevy, 1959 Viking 60 LCF
1974 Elcamino SS, 1979 6500 GMC Tilt Bed Wrecker
Big Bertha Build
buggy5872 is offline
Old 06-11-2013, 02:25 PM   #2363
Daze57
Daze57's Avatar
Worked on under dash wiring most of weekend .making sure I am not gonna torch the machine when I fire it up . Tying up all bundles and makin it neat . Then worked on my heater( yeah I know 112 here and I am messin with a heater) like
Daze57 is offline
Old 06-11-2013, 02:43 PM   #2364
dubie
dubie's Avatar
we got damn near all of the wiring done, the cab is now carpeted and the seat has been upholstered and installed. The mini tubs have been welded and are ready to install and the aftermarket rad has been mounted. This week will consist of coolant line and fuel line plumbing, plugs, carb, wires, exhaust manifolds and then we'll look at bleeding the brakes and firing this ***** up
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline
Old 06-11-2013, 05:20 PM   #2365
Dan in Pasadena
we got damn near all of the wiring done, the cab is now carpeted and the seat has been upholstered and installed....
I don't believe you, I have to see photos!
Old 06-11-2013, 06:31 PM   #2366
dubie
dubie's Avatar
Check my build thread bud
dubie is offline
Old 06-12-2013, 10:21 AM   #2367
mknittle
mknittle's Avatar
I got tired of the one step forward two steps back transmission dance and drug out my old Muncie M20. I spent most of Monday cleaning it between rain showers.
Yesterday I cleaned up a bell housing and started on the cross member. The idea is to make a cross member to fit a S10 T5 and with a bolt on adapter for the Muncie. That way I can swap in a Camaro/s10 T5 pretty easy later on. I want to get the frame done and painted in this summer.
Mark
My GMC build.
mknittle is offline
Old 06-12-2013, 11:24 AM   #2368
buggy5872
buggy5872's Avatar
Old tranny out and new one back in...only took 4 hours.....
Big Bertha Build
Old 06-12-2013, 11:31 AM   #2369
RedneckRodder
Good lord you work quickly! I'm starting to think I need a motivator as important to me as your camping trips are to you!
Old 06-13-2013, 09:34 AM   #2370
buggy5872
buggy5872's Avatar
The wife and kids wanting to go camping is most of the motivation.
Big Bertha Build
Old 06-15-2013, 04:37 PM   #2371
Russell Ashley
Russell Ashley's Avatar
I made a new battery hold down. I bought an original style battery tie down but it won't go over the battery due to the extensions on the ends, so I used the rods that came with the set and a piece of aluminum angle sprayed with Rustoleum textured paint. At least it looks better than the plastic wrap-tie that I was using to hold the battery down.
Russell Ashley is offline
Old 06-15-2013, 05:34 PM   #2372
Denee007
Denee007's Avatar
That looks great Russell, sometimes I wish I had left my battery in the engine compartment. Servicing the battery under the truck even with the drop down is a struggle
'72 Ford Bronco project(July 17 2021-?)
https://67-72chevytrucks.com/vboard/...d.php?t=828015
59 Apache (sold 6-25-2021)
67 Ford Mustang (re-restored after Harvey)
1968 Jeep Cj5 (2-8-2020 to present)
1992 Jeep Yj (8-17-20 to present) (Jurassic build)
www.Classiccarsandtools.com
Denee007 is offline
Old 06-15-2013, 06:09 PM   #2373
Russell Ashley
Thanks D'ne. It does tidy up the firewall to move it, but I've had 1953 and 1956 Ford trucks with the battery under the floor (factory) and I prefer the under hood location.
Old 06-16-2013, 12:52 AM   #2374
mknittle
mknittle's Avatar
That's part of the exercise program!
I know you have back problems. My wife had surgery about a two months ago
they installed a device that looks like a little leaf spring shackle between #s 5&5 vertebras.
Mark
My GMC build.
mknittle is offline
Old 06-16-2013, 11:23 AM   #2375
Dan in Pasadena
....Servicing the battery under the truck even with the drop down is a struggle
What's to service? With modern batteries being sealed I don't get the reference? I ask cause I intend to move mine down there. When I still had a generator the voltage regulator was slightly off, overcharged the battery a it puked a little acid on my new finned valve cover. Seriously pissed me off!
As for those "extensions" on the battery Russ? I just cut them off and used the stock hold down frame.
Closed Thread
