![]() Join Date: Jun 2010
Did Chevy make a "Hi-Boy" version?
The guy I bought my K30 from said he had what he called an 83 Chevy Hi-Boy 4x4. I know the Hi-boy is a ford term but that is how he put it to me. He said from the factory it set up pretty high like it had a factory lift kit or something. I am thinking he said it was a 3/4 ton 4x4 chassis. just curious.
Roy 85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818 1987 R10 shortie |
Re: Did Chevy make a "Hi-Boy" version?
Last year of Chevy building a 4X4 pickup that resembled a "Ford Hi-Boy" was 1966.
My thought was they didn't but I wasn't for sure.
If it was lifted from the "factory", it was actually most likely done by the dealer.
A true 1 ton will sit 2" higher than a 1/2 or 3/4 ton will. The frames are 2" taller....
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon 350/4L60 6" SAS |
High boy was a nickname for factory lift on a 70s ford truck ,As far as i know gm never done it but like said a 1ton will **** higher then the rest of the trucks.
#7 | |
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
yes you are correct...
Here are the facts guys :1966 was the last year of the "Hi boy" pickup (repeat of earlier post #2).
Watch out for your cornhole !
![]() Join Date: Jun 2003
He's right with that diagram.
The Ford Hi-Boy used a divorced transfer case. Posted via Mobile Device |
its not. the rails above the cross member on my buddies half tone where highrer than the ones on his 1 ton
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
