Old 05-25-2013, 10:13 PM   #1
downbytheriver
downbytheriver's Avatar
Trying to iron out new suspension/wheels/tires
Just want to make sure before I start ordering:
I currently have a 68 stepside that will lowered in the front with a 4.5" ECE kit. The back will be lowered using air bags.
My plan is this:
15x8 front, 4" backspace 235/70/15
15x10 rear, 4" backspace 275/60/15
I do not want the wheels sticking out past the fenders. Also, I would like the widest back wheel I can without sticking out from the fenders. Will this work without rubbing? I do realize I will have to trim the LCAs slightly. I researched for hours today, and just want to make sure this all will work before I spend the $$. My brain is fizzling out
downbytheriver is offline   Reply With Quote
Old 05-25-2013, 10:24 PM   #2
TrixR4Kids
TrixR4Kids's Avatar
Re: Trying to iron out new suspension/wheels/tires
Subcribing..
~ Dave
'68 C10 Stepside: 350/700R4
TrixR4Kids is offline   Reply With Quote
Old 05-25-2013, 10:34 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
10's will stick out past the rear fenders.
I would run 15x7's and 15x8's.
Keith
Convert to disc brakes.
Old 05-25-2013, 10:39 PM   #4
Zoomin
Man of Mini-Talents
Zoomin's Avatar
With 4" backspace. Go with 5" and you should be good with 8's and 10's
Zoomin is offline   Reply With Quote
Old 05-25-2013, 10:44 PM   #5
lolife99
lolife99's Avatar
A 15x8 with 5" backspace won't work up front.
4" backspace is the max with a 15" wheel.
Keith
Old 05-25-2013, 10:52 PM   #6
downbytheriver
Haha well i guess it's good that i didn't order those.
At least it'll save me some money for the ls swap
Old 05-25-2013, 11:05 PM   #7
Zoomin
Man of Mini-Talents
Zoomin's Avatar
I completely missed the 15" part, was thinking 20's? N/m
Old 05-26-2013, 09:01 AM   #8
lolife99
lolife99's Avatar
20's would look good on your stepside.
This truck belongs to member hot trux.
All 4 are 20x8.5's that tuck perfectly,...
Keith
Old 05-26-2013, 12:28 PM   #9
downbytheriver
I love that look, but I'm going for an old beat up sleeper. I'd like to get a set of 20s to autocross with once in a while. I think that'd be much further down the road though.
What tire sizes do you think for thje 15x and 15x8? I'd like them somewhat even, and not all 'pro streeted'. I would like to fill up the fender well more though.
Old 05-26-2013, 12:48 PM   #10
Daaaanz67
My truck is only 4/6 15/8 with 255/60/15
Daaaanz67 is offline   Reply With Quote
Old 05-26-2013, 01:07 PM   #11
downbytheriver
That looks killer. I thought I had my mind made up on soft 8s, but it came down to those or rallyes.
I might have some rubbing issues in the front with another 1/2" of drop with 8s though.
Old 05-26-2013, 02:47 PM   #12
Daaaanz67
I doubt it look closely at the space above that front tire. Maybe someone who is running your drop can chime in on my set up and your drop.
Old 05-26-2013, 02:53 PM   #13
Robznob11
Robznob11's Avatar
If you go with a 15x10 you need atleast 4.5 bs and then your going to have to trim id get 5.5 bs if i were going with 10 wide. I have 15x12 with 6.5 bs on mine and i trimmed the lips nearly flush with the outter skin to clear. Also be sure to get a delux adjustable track bar it will keep the side to side movement to a min. As stated 4"bs on front is max i have 15x8 with 4 " bs on front and just clears. Some have to grind spindle and a arm a touch.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 05-26-2013, 11:40 PM   #14
downbytheriver
I found out that the 15x8 soft 8s can come in a 4.75" backspace, so I'm going to order 15x8s all around. I may have to do some grinding, but that backspacing should help. Rallye wheels have a 4" backspace if I'm not mistaken?
Tires, I think I'll be doing 255/60/15 T/As like yours, daaaan.
I do have the adjustable panhard, and the only things left to buy are the rear shocks and the shock relocation kit.
Old 05-30-2013, 10:51 PM   #15
downbytheriver
Okay, about to pull the trigger. Here's my (more-researched) plan:
front- 15x8 4.75" bs 255/60/15
rear- 15x8 4.75" bs 275/60/15
with that backspacing, it should pull the wheels in a little. Am I right in thinking that these won't rub with how I want to lower it?
Old 05-30-2013, 11:00 PM   #16
Robznob11
Robznob11's Avatar
Im not sure the kit your going to use on front but if you run a 2.5 drop spindle with a 15 wheel 4"bs is max or the spindle and or control arm will contact wheel!
LED TAILS
Old 05-30-2013, 11:08 PM   #17
downbytheriver
Ah, this is quite the juggling act...bring the wheels in far enough without going so far as to drag the rim on the control arm/spindle.
Old 05-30-2013, 11:43 PM   #18
Daaaanz67
Think rally wheels are actually 4 1/4 bs
Old 06-09-2013, 12:01 AM   #19
downbytheriver
Thanks for the help, guys!
here's what they look like now:
