Old 11-28-2010, 09:48 PM   #1
TheWhiteElephant
God is good!
TheWhiteElephant's Avatar
Battery Ground Location
I am routing my underhood wires to make for a cleaner appearance. I have the battery ground cable that grounds to the alternator bracket (passenger side).
It would look much cleaner out of sight. There is an empty bolt hole under the fuel pump rod bolt hole. Would there be anything wrong/risky in grounding it there? I don't think so but I've never done this. Thanks.
Mando
"It takes a smart man to know when he's stupid." -- Barney Rubble
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367
TheWhiteElephant is offline   Reply With Quote
Old 11-28-2010, 10:39 PM   #2
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
Re: Battery Ground Location
I am really not an expert here...but I think you should be able to ground your battery there....I'm pretty sure you can ground your battery just about anywhere right? Like the chassis?
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
Old 11-28-2010, 11:04 PM   #3
KQQL IT
At the body shop.
KQQL IT's Avatar
put a star washer for a good ground. i use the front of the head.
Old 11-28-2010, 11:08 PM   #4
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
So, whats up with the water pump gasket? lol, i'm curious!
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily.
04 Pontiac GTO
04 Ford Mustang GT
68 C20 LWB stripper truck
73 K5 Cheyenne
76 C20 Sierra Crew SRW
88 K20 Suburban
I'm not hammering on metal just to hammer, i'm creating a piece of art.
1BadSS is offline   Reply With Quote
Old 11-28-2010, 11:10 PM   #5
THE "10" SILVERADO
Oops I read something wrong so there isn't a point to this post
Michael
Old 11-28-2010, 11:33 PM   #6
flamingbig10
6.0 powered square
flamingbig10's Avatar
I have my battery mounted in the bed, I have the large cable bolted to frame and I have the smaller wire grounded to the bed floor, then I have a ground strap from the block to the frame, block to body, and body to frame
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 11-28-2010, 11:43 PM   #7
KQQL IT
At the body shop.
KQQL IT's Avatar
Lol a trashcan fix for a blown out gasket. Been there for two years. Milk duds to be exact
Old 11-28-2010, 11:57 PM   #8
msgross
msgross's Avatar
just make sure your small ground straps go from the block to the frame and frame to the body... then you can ground anywhere you like. I would do block or frame.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 11-29-2010, 01:02 AM   #9
willett
Another Day, Another Dollar
willett's Avatar
hang on, your trying to clean your truck up under the hood, but you have a milk duds package for a waterpump gasket.
lol
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 11-29-2010, 01:10 AM   #10
flamingbig10
6.0 powered square
lol
KQQL IT was showing his ground cable location not the road side repair
Aaron
Old 11-29-2010, 01:23 AM   #11
GMC Guy
GMC Guy's Avatar
you should trim off the excess for a cleaner appearance
Greg
1974 GMC
1/2 Ton SWB Fleetside
L33 5.3/4l65e
.................__
............._____l __\__
..............l_(O)_ l___(O)]
GMC Guy is offline   Reply With Quote
Old 11-29-2010, 01:26 AM   #12
nbpro
sweet water pump gasket
nbpro is offline   Reply With Quote
Old 11-29-2010, 09:56 AM   #13
KQQL IT
At the body shop.
KQQL IT's Avatar
dont laugh too much its lasted longer that the fel-pro gasket
Old 11-29-2010, 05:20 PM   #14
Acrophobia
Acrophobia's Avatar
No laughing here....thats old school style points!!!
Acrophobia is offline   Reply With Quote
Old 11-29-2010, 11:05 PM   #15
TheWhiteElephant
God is good!
Thanks a lot, guys. I appreciate the input.
Mando
Old 11-30-2010, 12:50 AM   #16
willett
willett's Avatar
no harm intended, it was just a funny observation
Old 11-30-2010, 01:08 AM   #17
bhummell
bhummell's Avatar
yes you can run ground strap there . just make sure it is clean and you can run another from there to the frame. as far as body off back of block to the firewall.if you can find the flat strap braids that is what came on most. and when clean look nice. and yes use star wasers.
1970 CHEVY MONTE CARLO NHRA/IHRA STOCKER
1976 PONTIAC GRAND PRIX ORIGINAL EXCEPT INTAKE AND CARB
1979 3/4 TON CAMPER SPEICIAL PROJECT
bhummell is offline   Reply With Quote
Old 12-01-2010, 03:15 AM   #18
KQQL IT
At the body shop.
KQQL IT's Avatar
None taken at all
i hadnt seen the pic in two years got a LMAO...
Old 06-09-2013, 01:59 AM   #19
JOJABOY
2013.....Im curious if the milkdud box is still hanging tough?
JOJABOY is offline   Reply With Quote
Old 06-09-2013, 03:20 AM   #20
Pop's C-10
Pop's C-10's Avatar
This...lol
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 06-09-2013, 04:08 PM   #21
electrician42
electrician42's Avatar
Sweet fix...
2011 silverado 2500hd ext. cab 6.0
2007 tahoe lt
2004 harley-davidson superglide
1982 chevrolet c10 stepside 2 wheeldrive..current project
electrician42 is offline   Reply With Quote
Old 06-09-2013, 04:10 PM   #22
JOJABOY
I've made thermostat gaskets from brown office folders many of times. But never from a candy box out of the trash. Sweet, Redneck Engineering. Gotta love it.
Old 06-09-2013, 04:15 PM   #23
Sillyoldman
#16876
Sillyoldman's Avatar
^Lots to chew on there.
Posted via Stationary Device
'71 Custom Deluxe C-20 402.
'67 Buick Special 455.
'49 Plymouth Special Deluxe.
"I love that old car smell"
Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Sillyoldman is offline   Reply With Quote
Old 06-09-2013, 04:47 PM   #24
mooseknuckles
mooseknuckles's Avatar
I've used that one before, make sure to clean off the paint and crap to get a good ground, use a serated washer...
mooseknuckles is offline   Reply With Quote
Old 06-09-2013, 05:39 PM   #25
KQQL IT
At the body shop.
KQQL IT's Avatar
Lolol still there since. The edges have weathered but still going.
